Question about Lexmark P4350 All-In-One InkJet Printer
My Lexmark printer when turn on it makes noise and it can not print with a error code 2200
Posted by gbondo_t on
Muhammad Uzair
  • 812 Answers
Hello thanks for using Fixya
The 2200 error message indicates a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message.
Step1.
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes:
Continue to step 2.
No:
Attempt a test scan. If the error message does not reappear, the error is resolved.
Step2. Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.Did the error message return?
Yes:
Continue to Contacting Lexmark.
No:
Continue to step 3.
Step3: Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes:
Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No:
Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Step4: Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes:
Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No:
Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Posted on Feb 11, 2011
A code 2200 is showing and my copier will not copy. How do I address code 2200?
The 2200 error code indicates that the scanner has stalled. It could be due to the cartridges or the encoder strip (transparent strip seated behind the cartridge carrier) has gotten loose from its position. Please follow the steps below to identify and fix the problem:
  1. Open the printer cover and remove the cartridges. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then slide the carrier to the center for the loading position.
  2. Check the encoder strip and make sure it is secured in its place.
  3. Close the printer cover.
  4. Re-brick your printer. Pull out the power supply (black box where the power cord is plugged in at the back of the printer) and put it back after 30 seconds.
  5. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  6. If no error appears, reinsert the other cartridge. Close the printer cover.
  7. Replace whichever cartridge is causing the error to appear with a new cartridge.
  8. If no error appears, try to print a document again to verify that the problem is fixed.
Feb 02, 2012 | Lexmark X7170 All-In-One InkJet Printer
Show error 2200
The 2200 error code indicates that the scanner has stalled. That's why you're not able to make a copy. Please refer to this article on the Lexmark website to fix the problem:
2200 Error on the Lexmark X7100 Series All-In-One
Should the error continue to display, please don't hesitate to contact Lexmark Technical Support Center for additional assistance.
Dec 11, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
It does not copy or print it displays error 2200
The error indicates the has stalled or jammed. This article in the Lexmark website on 2200 Error on the Lexmark X7100 Series All-In-One might help fix the problem.
Mar 21, 2011 | Lexmark X7170 All-In-One InkJet Printer
What is error 2200 why is scanner making noise?
The 2200 error indicates the scanner has stalled. Please refer to this article on 2200 Error on the Lexmark P4300 Series All-In-One. Hope this helps. Thanks.
Jan 17, 2011 | Lexmark P4350 All-In-One InkJet Printer
Error 2200
Here's a link to the Lexmark website to guide you on what to do when havine Error 2200 on the Lexmark X7170 printer. http://bit.ly/b6mEyP. Just follow the instructions carefully. Hope this fixes the problem but if all else fails, I strongly suggest you contact Lexmark Technical Support for further assistance.
May 15, 2010 | Lexmark X7170 All-In-One InkJet Printer
Error:2200
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 13, 2009 | Lexmark X7170 All-In-One InkJet Printer
Lexmark x7170 will not copy
unplug the power pack in the back for about 30 seconds the plug back in
Nov 22, 2008 | Lexmark X7170 All-In-One InkJet Printer
Lexmark P4350 All-In-One InkJet Printer Logo
323 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Michael Thomas
Michael Thomas
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
