How can we download psp games now
these are the steps you will use to download a game on your psp.
step 1
Your regular PSP games will come on disc, or UMD as
they are known. When you download games onto PSP however, you are going
to be putting them straight onto a memory stick/card. (Some people call
them memory sticks, and some people say memory cards, but they are in
fact the same thing.) The standard PSP memory card of 32mb is just not
going to be big enough to download games onto, PSP owners should
generally get the largest one they can afford. These days you can find
fairly affordable 2 or 4 gig models on Ebay and Amazon quite easily.
Once you have your new memory card, you will need to format it before
use. This is basically like wiping the slate clean before use, so be
sure to do it.
step 2
You
will need to locate somewhere to download the games from. There are
hundreds of places online that will allow you to download games onto
PSP, but unfortunately they are not all reliable-if you go to the wrong
places you will encounter many problems and can even find your computer
riddled with spyware after. Not good! Be sure to choose a reputable site
to download PSP games from-the most reliable ones are the ones that
charge a small fee upfront and then give you access to unlimited
downloads.
step 3
Once
you begin downloading to your computer, be sure to only download files
that end in "PSP" or have "PSP" in the title, as they are the only files
compatible. You will occasionally find that the untrustworthy sites out
there will try and give all kinds of files as downloads, so be sure to
double check everything before you download it. When downloading the
games I save them to a little folder on my desktop called "PSP
Downloads, as it's simply the easiest place!
step 4
Now that you have a selection of games
downloaded, you will need to transfer them from your PC onto the memory
card of your PSP. This is pretty simple, all you will need is an
ordinary USB cable to connect the two, and the PC should then identify
the PSP as some form of removable drive, like a flashdrive or removable
HD. All you need to do from here is to open up the PSP using the PC and
drag and drop the required files onto the PSP memory stick, much as you
would with any other removable drive. When you are doing this, be sure
to send the files into folders called PSP, and then GAME on your memory
card. If they don't exist you will need to create them, and I would
recommend using all caps.
step 5
Once the transfer is finished you should be able to play
the games on the PSP by simply opening up the GAME menu and selecting
the games from the stick. Any errors or error messages are likely to be
due to incompatible firmware-this is especially true if downloading
homebrew games. You may find it necessary to downgrade your PSP in order
to play these homebrew games.
Hopefully this guide has helped you
see that it's not that tough at all to download games onto PSP once you
get the hang of it, the real trick is finding a reliable download
source!
Please rate my solution.
Thanks
