My kodak esp5210 printer is showing paper jam remove rear access cover. clear all papper. attach cover. press ok to continue. (code 3533). ive followed the instructions but nothing changes. there never was any paper in it to start with. its brand new.
imaginthaton
    New Friend:
I have an ESP 5250, I got the error code for the paper jam. I read where a poster above said theirs worked after they took the back cover off, and printed it that way. So, I thought I'd give it a try.
I removed the rear cover, but the same error code remained. Immediately after I'd hit the Ok button, the code was back.
I left the rear cover off, spammed the Ok button, and after about 10 times in rapid succession, I hear a very distinctive click in the rear--I replaced the cover, and now it works.
Posted on Jan 12, 2013
Anonymous
    New Friend:
I've got exactly the same situation/circumstances and error code, the thing different is that my code changes between 3533 and 3528? sorry I;m no help right now but I'll be back if I solve it. Martin. ([email protected])
Posted on Feb 28, 2011
  • acupoftea May 24, 2011
    We've had the same issue with a 5210 since we bought it, but today was the last straw!
    I just found that leaving the back cover off completely seemed to do the trick. Like others, we kept alternating between two error codes. Needless to say, there was no paper jammed or anything. So I phoned the helpline and they arranged to have a replacement printer delivered in a couple of days (he was very friendly and helpful).
    Lo and behold, I thought I'll give it one last try without the back cover on. It's worked every time for the last hour since I phoned the helpline. Do I cancel the replacement now? Hmmmm ....
My kodak printer esp 3.2 is giving me an error code 3533 paper jam but there is no paper jammed and when i put new paper in it, it still wont print and keeps giving me the same error code 3533
Turn off the printer and unplug it. Open the top access panel. Inside on the left you will see three round, white gears. Rotate the gear closest to the front back and forth with your finger. If any scraps of paper appear near the rollers, remove them. Close the top access panel. Plug in and start the printer. This worked for a Kodak ESP 3.2.
Sep 12, 2013 | Kodak ESP C310 AllInOne InkJet Printer
Get a paper jam error code 3533 but nothing in the copier. caution spam number below
I hit on mine several times and slammed it on the table a few more times and it cleared the jam. Seriously.
Apr 04, 2012 | Kodak ESP C310 AllInOne InkJet Printer
My new kodak printer says the following:Printer error remove rear access cover.Clear all papers Attach cover press ok to continue code 35 28. (The cover will not remove and I cannot see any paper stuck....
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now remove the covers and reset and check the printer properties to see the ink levels.
Activate head cleaning before a test is taken.
Sep 17, 2011 | Office Equipment & Supplies
I've just bought a new kodak printer ESP3250 last week, and installed everything and got it set up fine. It was printing fine after I installed it but suddenly stopped after I had printed a few sheets. The...
Sounds like there is a sheet of paper jammed in it. Try taking off the roller access panel in the back (not the access panel by the cartridges). Make sure to only use clean sheets with proper humidity level to avoid jams. Also fan the sheets before feeding to disperse any static.
Mar 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 3250 printer error. Remove rear access cover. Clear all paper. Attach cover. I removed the paper, and pressed "ok" to continue, reattached the cover, and it still says this. I tried...
To resolve the error condition:
1. Disconnect the power adapter from the printer.
2. Wait 30 seconds to allow the printer to reset.
3. Connect the power adapter to the printer. Turn the printer on if necessary.
4. Wait until the printer is ready to use.
If the error condition continues:
1. Open the printer access door.
2. Remove and install the print head two times. - See http://faqs.kodak.com/atg/faq/attachments/AUR1780-2.pdf
3. Close the printer access door.
5. If the error is still displayed, contact Kodak
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 29, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 5210 code error 3533 paper jam no paper in it
Leave the rear cover off, then spam the OK button if the error message remains on. I did that maybe 10 times in rapid succession, then hear a very distinctive CLICK in the back of the printer. I replaced the cover, the hit OK, the printer cycled through startup, and now it's operating normally.
Jan 17, 2011 | Kodak ESP 5 Printer
When i try to print with my esp 3250 it says error: paper jam remove rear access cover. clear all paper. attach cover. press OK to continue.. but it doesnt work???
on the back there is a gray cover on the back right side there is a tab u push in and pull it out but mine is doing the samething and there is no paper in it
Jun 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer papper jam cant see any papper mfc-240c
Did you remove the rear cover and check for paper there? If it still shows a jam and there's absolutely no paper inside the printer, you may have to shut it off (or unplug it if it won't turn off), wait a few seconds, and turn it back on to clear the jam detection.
Sep 05, 2009 | Brother MFC 240C All-In-One InkJet Printer
Printerjam
A paper jam error message will appear if the printhead is not correctly installed. Try removing and reinstalling the printhead again, but make sure it snaps into place. Try loading a sheet of plain paper and press at the same time copy+cancel; hold them down until the printer feeds the paper. The paper will go through the rollers and come out blank.
Apr 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
1,360 people viewed this question
Marvin
Marvin
