Question about Nokia 3110 Cellular Phone
Hello sir, i am using nokia 3310 mobile ,our mobile charge backup is very low ,please reply the solution
Posted by bakyaraj_83 on
Anonymous
    Sergeant:
  • 194 Answers
Your phone battery is the problem.Replace it with an original item having nokia logo hologram
Posted on Feb 11, 2011
I forgot passlock password in nokia 5233
Hello My Dear:::::"::
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Jan 19, 2013 | Nokia 5233 Cell Phone
Security code for nokia 3310
Hello My Dear Friend:
Dec 22, 2012 | Nokia Cell Phones
Sir, when i call in nokia 3220 infew moment display show battery low &shut down immidiately &again switch On battery show full what is problem ?
Please try this solution:
  • First try to remove the battery then wait up to 10 seconds then put it back again.
  • Then power on the mobile phone then try to make a call. Make sure that the battery is in full charge.
  • If the its still the same issue the problem is the battery.
Please reply if you have additional questions. Thank you.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Sep 13, 2011 | Nokia 3200
Hey i am unable to charge and on my mobile nokia 3310
The phones Charging IC is damaged,
If you allready tried another battery and another charger.
to fix charging IC contact Nokia service
May 09, 2010 | Nokia 3310 Cellular Phone
How to upgrade my 3310 to 3315
If you only wanted to Know procedure, this is exactly how you need to go about it :-
To upgrade 3310 to 3315 you need to reflash your phone to new version. Seems to be first version used both in 3310 and 3315 (Asian version of 3310). After 5.45 firmware for both is the same. From this also changed PPM packs (for example, Polish is now saved in "N", not in "J").
First of all you must remove SimCard from phone and charge battery.
Below you will find full step by step solution:
1. By using Universal Box v3.0 make a backup of flash from your phone with range 200000 - 400000 (it will be safe backup if somethign will goes wrong). If you don't have Universal Box v3.0 you can use standalone Dejan Flasher and Mbus cable.
2. With Universal Box v3.0 or Dejan Flasher upload software 3315 (v5.45) that can be downloaded from our Free flashes-> Nokia page - please take oportunity to vote for us. Start address is 200000
3. After flashign operation ended run software KNOK that can be downlaoded from our page "Free Download-> Nokia". Connect phone to function RJ in Universal Box or if you don't have Box use Mbus cable. In Mbus function choose - Phone Settings -> Quick set FAID
4. Then choose Phone Settings -> Set new imei - and enter IMEI of phone. You can read it on back of phone.
5. Then choose Modify Lock -> Reset SP lock. After ended this choose once again "Phone Settings -> Quick set FAID "
6. All is completed. If phone require security code please enter 12345.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 12, 2009 | Nokia 3310 Cellular Phone
Hello sir, i have HTC 3400i mobile phone i want
There is software named autosync in your cd which you have got while purchesing.Please install that software on your pc and connect the phone to pc.Automatically you will get backup.
Jul 13, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
I lost my mobile securety code plz help me
unlock.nokiafree.org
Use IMEI number to unlock.
May 25, 2009 | Nokia 1209 Cell Phone
Nokia 6280
SIR I LAST DISPALY OF MY MOBILE WHAT IS THE COST OF THAT ONE
Dec 29, 2008 | Nokia 6280 Cellular Phone
Reconnect charger nokia 3310
do this sir ur problem will be ok.
Jun 29, 2008 | Nokia 3310 Cellular Phone
Nokia 3110 Cellular Phone Logo
Top Nokia Cell Phones Experts
Resolution IT Dubai
Resolution IT Dubai
matt
matt
aliasger yq
