Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
Approx half a centimetre of left side of page does not print even though it is visible in Print Preview. Margin area is 1cm. When printing in duplex, the print on the entire page shrinks in size.
Posted by gary_stok833 on
  • gary_stok833 Feb 11, 2011
    Thankyou so much, the problem has been solved.
    Yes, I was able to print my document out as I wanted so I was very happy!
Benjamin Jr Singson
    Genius:
  • 1,570 Answers
Hi
It sometimes coming like this. You need go to page set up and adjust the FIT to page to 1 page only. Also try to adjust the zooming size of the page from that page set up. If it fits to 80% try to put 78% to fit all the print document.
From there you can adjust the print page setting. I hope you get what I mean.
Regards.
Posted on Feb 11, 2011
  • Benjamin Jr Singson Feb 11, 2011
    I am glad to help you but don't forget to accept this solution. Thank you for using fixya.
Printing only left side of a page, right side totally blank
What application are you using to print text? Word?
Try a simple application, like Notepad or Wordpad, to print some simple two-liner text.
Does printer print ALL the text on left side or just the half of printable material?
Even if you are indicating that page size is correct, looks to me some problem with the selection of print area.
Oct 03, 2015 | Dell 926 All-In-One InkJet Printer
My printer -X1185 prints the page with a 3 inch blank area on the left side and some of the right side printing is off the page. This is typical in my e mail page, and even if I center the letter on...
Web site designers create Web pages for display on a monitor, not for users to print on 8.5- x 11-inch pieces of paper. This becomes obvious the first time you try to print a Web page. Content you need may get chopped off by the right printer margin, whereas content you don’t need, such as the site’s copyright information, will print on its own sheet of paper. Fortunately, you can avoid such problems with a little foresight.
Before printing any Web page, open Internet Explorer’s File menu and select Print Preview. The current Web page will appear on-screen exactly as it will print on paper. Scan the preview carefully. If it appears that some content is chopped off by the right margin, click the Page Setup button located directly to the right of the Print button in the upper-left corner of the Print Preview window. In the resulting Page Setup dialog box, adjust the left and right margins so that each is set to 0.25 inches. The extra inch of space you gain by resetting the margins should provide just enough room to accommodate all of the content on most sites. Click OK to save the changes and return to the Print Preview window.
Next, scan the preview to determine which pages contain the content you want to print. Take note of those pages and click the Print button in the upper-left corner of the Print Preview window. Locate the Print Range heading and select the Pages option. Type the number of the first page you want to print in the From field and type the number of the last page you want to print in the To field. For instance, if you want to print just the first three pages of a Web page’s content, type 1 in the From field and type 3 in the To field. If your browser doesn’t have To and From fields, type the range of pages (such as 1-3) in the corresponding field. Make sure your printer has paper and click Print.
May 04, 2008 | Office Equipment & Supplies
I am trying to print a booklet 2 pages per sheet double sided. Printing is OK but spacing is no good for the binding when the pages are cut in two. What instructions should I give the printer to allow...
Hi
By spacing, I assume you mean the margins at the centre.
The default margin settings are not the same for the right and left hand side of the page, so the printing on the reverse side is offset from the printing on the first side.
The right margin is always wider to allow for punch holes in file paper.
It is not the printer settings you need to adjust, it is the page layout of your word processing software.
Adjust the margin settings manually. In MS Office 2007:
Page Layout > Margins > Mirrored Margins.
Hope this helps.
Aug 24, 2011 | Canon PIXMA MP610 InkJet Printer
Is there anything I can do to print closer to the top of the page? Even when I have my top margin set to zero it starts printing an inch from the top. I have it set to center on the page. In print...
if you print web pages, click File, then click Page Setup, from there, adjust the top margin. Do the same on the application you are using for the document or file you are working on.
Aug 29, 2010 | Office Equipment & Supplies
In Print Preview my booklet looks like it will print correctly. When I print my book the 1st page of the 2nd half of the book prints on top of the last page of the 1st half of the book. I have tried...
rint Preview my booklet looks... Solve In Print Preview my booklet looks like it will print correctly. When I print my book the 1st page of the 2nd half of the book prints on top of the last page of the 1st half of the book. I have tried
Sep 11, 2009 | Microsoft Office Professional 2007 Full...
The printer will not print on the half inch left edge of the page.
go to settings and change the left margin to 0.0. if in Word, then file->page setup and set the margins to what you want, left margin to 0.0 in your case.
Sep 02, 2009 | Laser Office Equipment & Supplies
My Epson Color 3000 will not print the entire image. It prints well from left margin to center of page and dosen't print to right margin. Half of the image dosen't print.
see the printer settings. adjust the page setting or try to see the print preview before printing. if the problem still persists visit the mentioned link for free diagnosis.
http://tinyurl.com/m7ghqz
Jun 18, 2009 | Epson Stylus Color 3000 InkJet Printer
My Pages Are Printing Off The Page
If you still have your printer manual. Look up the instructions for calibration. That will fix it.
Jan 01, 2009 | Canon PIXMA MX310 All-In-One Printer
Printing problem with Microsoft Office for Mac 2008.
have you clear the set print area? if not go to File menu, select Print Area then select Clear Print Area
try also to set your sheet into page view to find out if you can view right page of your sheet.
try also to check your margin.
Dec 14, 2008 | Microsoft Office 2008 for Mac: Mac
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
efs_perpends
efs_perpends
k24674
