Question about Epson EMP 7600 Multimedia Projector
There is no yellow colour in my emp 7600, can you help me how to solve this problem
Posted by first_dedi_y on
Robin Bonathan
  • 699 Answers
Yellow light is made up of red and green light.
Your projector has 3 LCD panels. You need green and red to make yellow.
go into the menu and check that all the colour values are reset back to standard.
Posted on Feb 11, 2011
My epson projector shows a non growing yellow tinge in the centre of the image. The projector is about 4 years old. EMP-TW700. I am a fairly heavy user.
From my experience, the projector bulb has most likely received a blemish of some kind from something such as accumulated dust on the front, to a fingerprint from where it has been handled by someone replacing it.
This yellow tinge then occurs when the blemish is burned onto the surface of the bulb.
In my opinion, unfortunately, you may need to get a new bulb.
Hope this helps!
Mar 03, 2011 | Epson (V13H010L32) Projector Lamp for...
Help w/ h/p deskjet 3520
hi/....
this is because of the low ink in the catridge. normally the colour catridge contains three colour in it. yellow ,blue and i think one more is pink. so in your case the other colours might have finished. so because of that you are getting only yellow. so please replace the catridge with new one and the problem wil be solved
Jul 15, 2010 | HP DeskJet 3520 InkJet Printer
My pc (hp dc 7600 sff) giving yellow display during playing games & also not responding to well famous games. I tried my best 4 solving the problem but in vine.
Display Problems tend to be due to a few things. Mainly Hardware, and also software.
I would check the cables from the monitor to the computer. Make sure there are no bent pins. Maybe try a different cable.
Check the settings on the monitor. Maybe reset to default settings.
Check the drivers for the graphic card, that they are the latest ones.
Is the screen always yellow or only when playing games?
Is your DirectX software ok? Maybe re-download and re-install from the Microsoft website.
Does it happen on all games or just certain ones?
Oli
May 21, 2010 | HP Compaq dc7600 Small Form Factor PC...
Black and White picture when watching TV
Check color syestem of tv,select Auto
Jul 05, 2009 | Televison & Video
Black and white colour on tv
Hi there. Try running the multiple display wizard in the Nvidia control panel.
Hope that helps
Tim
Apr 17, 2009 | Evga e-GeForce® 7600 GTS, (256 MB) PCI...
My computer is distorting colour and going black
DRIVERS CAME CORUPTED OR RIGHT CLICK MOUSE GO TO PERSONALIZATION, DISPLAY SETTINGS MAKE SURE IT IS 16BIT OR 32BIT NOT 4 OR 8 BIT
GOTO ADVANCE SETTING TO TROUBLESHOOTING IF THEY HAVE IT NOT EXIT ALL PROGRAM AND REBOOT SYSTEM
ROD
Feb 05, 2009 | PNY GeForce 7600 GS,, AGP Video Card
My epson emp-50, gets off after ev.5 mins. says NO SIGNALS. but audio comes....pl.help
check for the error indicator in the projector, if the bulb light is flashing red, then i think you need to clean the units ventilation fan, if cleaning doesnt solve the problem, you have to replace the bulb.
Jan 29, 2009 | Epson (V13H010L13) Projector Lamp for...
Yellow green screen
If you are connecting it to a computer with a VGA cable, you may have to go into the options of the projector and set the port correctly.
Go into the menu, and select the "image" area. In here you should be able to select computer.
Aug 19, 2008 | Epson EMP-S3 Multimedia Projector
My printer will only print in blues pinks and purple and black and white
ur printer prints in blues pinks n purple: its very simple :there r three prime colours in ur colour cartridge that forms all the other colour variation they are cyan, magenta n yellow. ur yellow colour in ur cartridge is either dried or empty thats the reason its not printing the colour variations which requires yellow. the solution is to either get ur colour cartridge refilled or replace ur colour cartridge. rate this solution as fixya n encourage us to help u solve ur problems in future too.thanks 4 using fixya.
Jun 12, 2008 | Office Equipment & Supplies
Yellow hallo problem
It sounds like it is related to the red filtered glass before the prism inside the projector. When this gets to hot, it will burn a spot on the glass that causes the yellow spot. I have seen in happen on alot of epson 53c projectors. This has a red filter that is easily scratched when it gets too hot. It will actually look burnt.
Dec 27, 2007 | Epson EMP-830 Multimedia Projector
Epson EMP 7600 Multimedia Projector Logo
Top Epson Office Equipment & Supplies Experts
Falling star
Kyocera HP Expert
Kyocera HP Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
