Texas Instruments TI-84 Plus Calculator Logo
Posted on Feb 11, 2011
I just changed the batteries in my TI-84 plus and when i turn it on it says that the batteries are low and should be replaced, but i just bought them two hours ago
Anonymous
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Mar 06, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
35
Questions
0
Helped
27615
Points
65
You simply bought defective batteries.
2helpful
TI-84 cannot power up
TI calculators have an annoying habit of dimming the screen, especially when the batteries are changed, so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please reply to this post and we'll go on to the next step.
Just bought a ti 84 plus and it wont turn on pls help
Double check batteries and polarity first. If this doesn't help, return it to the store, you have a DOA (dead-on-arrival) machine. They're obligated to replace.
1helpful
My for the TI 84 Plus Silver Edition screen doesn't work. I changed he batteries including the back-up. The screen won't light up. I bought this calculator around 3 years ago.
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If that doesn't work, remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries.
If that doesn't fix it, please append a comment to this post and we'll go on from there.
9helpful
My ti 84 plus silver edition wont turn on. I
If that doesn't work, add a comment to this post and we'll go from there.
4helpful
My TI-84 won't turn on. If I replace the
Remove all four AAA batteries. Press and hold down the ON key for at least ten seconds. Replace the batteries. Turn the calculator on.
1helpful
I have a TI 84 plus silver edition. Won't turn
The problem may be due a screen that is too light to see anything on it. Adjust the screen darkness.
  1. Press [2nd] key and release it.
  2. Press and HOLD the [UpArrow] to draken screen.
  3. Release the [UpArrow] when screen is dark enough.
You can also connect it to the computer to see if TI Connect finds it. If it does, update the OS to version 2.53MP.
You change the backup battery if the calculator tells you RAM CLEARED each time you turn it ON.
TI-nspire will not turn on
Yes we changed out the batteries on now the TI-84 will not turn on HELP
2helpful
Blank screen with new batteries! TI-84 Silver Plus
ON, 2nd, [up] arrow to change the contrast. Works 99% of the time....
2answers
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
