Question about Olympus PEN EPL1 Body only Digital Camera
The LCD on my Epl1 has red flashes on all the images. Why???
54racing
    New Friend:
It sounds like you have turned on the Highlight/Shadow point warning. I use this all the time to check for blown out highlights.
You should press the INFO button in playback mode to cycle through the picture display options until you get back to the display that you like.
Posted on Mar 28, 2011
Does not flash
http://www.imaging-resource.com/PRODS/EPL1/EPL1FLASH.HTM
It may be switched off. There could also be a break in the wiring to the flash. Without more, there's no way to know.
The first step would be to verify that the flash has not been set to "off" in the flash mode.
Jul 14, 2013 | Olympus Cameras
I need a manual for vivtiar 3188
Product MPN MPN: 80640 Key Features Features: Red-eye Correction Camera Type: Compact Resolution: 3.1 Megapixel LCD Screen Size: 1.5 in. Optical Zoom: Without Optical Zoom Digital Zoom: 4x Lens Interchangeable Lens: Not Interchangeable Lenses Optical Zoom: Without Optical Zoom Focus Type: Autofocus Macro Focus Range: 7.87 - 11.81 in. (w) Focal Length: 6.1 - 18.3 mm Image Quality Image Sensor Type: CMOS Camera Resolution: 3.1 Megapixel Image Resolutions: 2560 x 1920 · 2048 x 1536 · 1600 x 1200 Video Video Resolutions: 640 x 480 (VGA) Video Speed: 15 fps Video Format: AVI Exposure Control Aperture Range: f2.8/f4.8 (w/t) White Balance: Auto · Daylight / Sunny (Preset) · Cloudy (Preset) · Fluorescent (Preset) · Tungsten (Preset) Storage Memory Type: Built-in · SD Card Built-in Memory Size: 16 MB Compression Type: JPEG Flash Flash Type: Built-In Flash Functions: Flash Off · Auto Flash · Forced On Viewfinder / Display LCD Protected Position: Without LCD Protected Position Interfaces Interface Type: USB 1.1 Video Interface: Video Out Power Supply Battery Type: 2 x AAA Batteries Included Features Built-in Microphone: With Built-in Microphone System Requirements Operating System: Microsoft Windows 2000 · Microsoft Windows 98SE · Microsoft Windows ME · Microsoft Windows XP Dimensions Width: 3.5 in. Depth: 0.8 in. Height: 2.44 in. Miscellaneous Family Line: Vivitar ViviCam UPC: 19643806405 Product ID: 44609540 Return to top
Aug 30, 2011 | Cameras
THE SCREEN OF MY LAPTOP (ASUS)TURNS PINK.Can anybody help me to solve this.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp)
has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 14, 2009 | Acer Aspire 5630 Notebook
Flickering, jittery image, white horizontal flashing lines
this is real old right
no photo off i messing up, how can we guess, what you see?
amazing....
my guess power pack shot.
i guess you cant barrow a monitor and try that?
2nd guess blind, the back light failing
or is damage if it was hit, the LCD will have damage
gently flex the frame goes nuts, bingo.
Mar 02, 2017 | HP Pavilion F1703 17" LCD Monitor
Zebra TLP 2844
TLP2844 does not support Line mode.
but the LP2844 does.
If you neeed to use line mode change your printer. from TLP2844 to LP2844.
I had this issue last week.
Jan 20, 2009 | Zebra TLP 2844-Z Thermal Label Printer
On Daytek LCD DT4040, After some time like 2-3 hour, sometime 10-15 minutes, image from source disapear and red and green line appear... Not actually on DVI input, no trouble since 30 minutes.. on test for...
i have a daytek dt 4040 and when i turn it on,i push the red button ,flash 5 or 6 time and turn green have sound but no image. what the problem
Aug 19, 2008 | Televison & Video
LCD Screen dead
This may be a dumb idea... but did you accidentally turn the screen off? Don't ask how I know this...
Dec 26, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Olympus PEN EPL1 Body only Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jax Planet
Jax Planet
Are you an Olympus Camera Expert? Answer questions, earn points and help others
