Question about Canon EF 50mm f/1.8 II Lens
My lens fell down and I think is not broken but the front part is separated, can I repair it myself or should I sent it to customer service?
Posted by jorge_sepulv on
djd1mm
    Scholar:
  • 42 Answers
I checked the damage and carefully reinserted the front lens.
The structure is quite simple:
  • There are three plastic clips holding the front lens in place
  • There is a plastic extrusion that makes the lens move in and out when the focus ring is moved
Just look inside and try to find the correct position and click it into place. If you have a friendly camera shop, you could ask them to do it for you...
Posted on Feb 13, 2015
Paul Green
    Prodigy:
    An expert who has answered 500 questions.
  • Canon Expert
  • 527 Answers
Get a quote first for the repair as this lens is the least expensive Canon lens and it could be that the combined cost of postage and repair will exceed to cost of a brand new replacement.
Posted on Aug 06, 2014
Lens repair ef
I doubt it is possible to repair. These lenses are mostly made out of plastic pieces. There is probably something broken and/or bent. Lenses are manufactured with extremely great care. When a lens element is only a millimetre or two out of alignment you probably will get faulty images (flare, unsharp, focus shift, etc).
Take it to a repair shop and have them examine the lens if that's free of charge. Without photo's it is hard for me to judge if its total loss or not.
Jan 02, 2014 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
My kodak M1063 fell while the lens barrel was out,i tried putting it off so that it will go in but it didnt move.So decided to push it in myself thinking it will come out when i put it on.Now,the lens...
Hi, Unfortunately it sounds like the camera is beyond repair. When a camera's dropped like that there's a 50/50 chance that a mechanism in the lens has been broken and it's repairable. From the sounds of yours though, the fact that it won't come back out when you turn the camera on, it sounds like you're better off getting a new camera.
May 12, 2011 | Kodak EASYSHARE M1063 Digital Camera
My phone fell down from a table and not working since then. Please tell me how to repair it.
Sorry, but I think in this situation you can't do anything without Nokia customer service assistance.
Check the link below to find the right contact information:
http://www.nokia.com/about-nokia/contacts/customer-service
Good luck
Mar 11, 2011 | Nokia Classic 2700 Cell Phone
My Nikon Nikkor 18-55mm lens will not automatically focus even when set to "A". I have cleaned it with canned air and the manual focus works fine. I want to repair it myself as Nikon has quoted...
hi there,
the motor inside your lens might have been broken,
was it fell down or hit something before?
if it`s still in warranty, you can claim it to Nikon Service Center
hope this post will help
Jan 05, 2011 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
My nikon D60 fell off due to strong wind and lens has damage !!
http://www.nikonusa.com/Service-And-Support/Service-And-Repair.page
May 04, 2010 | Nikon D60 Digital Camera with 18-55mm lens
Coolpix camera
It needs to be sent in for service. You may be better off buying a new camera since the repair cost will start at $100.
Sep 23, 2009 | Cameras
Dropped my canon powershot sd400, now it won't work fine
Hi there, there is two possibilities. The first one is to check the lens barrier covers at the front of the lens are opening correctly. If the front cap is dented in any way it may prevent them from opening fully when switching the camera on. If this is the case, you may be able to manually assist the cover by gently pushing them open with something soft like a cotton tip. This wont fix the problem but may temporarily allow you to use the camera. The other possibility, is that the shutter assembly inside of the lens has been damaged. If you gently shake the camera you may be able to see something shifting across the image on the screen or even when looking through the front of the lens itself. If this is the case you would need to have a service centre replace the lens for you. The same applies for the front barrier however that repair would be much cheaper. Best of luck!
Apr 14, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Broken glass on the lens
Are you kidding? A camera lens are a group of various lenses inside. I don't think it's repairable, but I'd say take it to a local photography store and you can get free advice. I think I understood you, but anyone would have to see the damage in person. From here, I'd say you are in bad luck...it's a goner. Also cameras are not designed to take a big fall like that. There is probably more damage than just the lenses.
Apr 04, 2008 | Sanyo VPC-CG65 Camcorder
Lens is stuck and will not power on
Hi ive got a solution to this
apparently i have some bad news , its the lense which is misaligned or broken in terms of gears, the thing to do turn on the camera and make sure that lens is out and then LIGHTLY tapp on the lens the direction of which you feel that the lens is not equal legnth to the outer ring > place that looks uneven
Nov 19, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Canon EF 50mm f/1.8 II Lens Logo
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
