Question about 5301 LE 2 Way Car Remote Starter System
Just notice blue lights flashing in the car. I unlocked, from inside the house, and manually locked from the lock on the inside door. That stopped the flashing blue lights. What has caused this? [email protected]
  • Anonymous Feb 11, 2011
    Thanks for clarifying the reason for the flashing lights. System is brand new and have not looked out the window at night, before last night. Good feature for sure. Thanks again
  • George palin Nov 12, 2018
    Why does light stay on when driving
Larry Spears
  • Viper Master
  • 625 Answers
Do not be alarmed; the blue light is flashing because you used the remote to lock/arm the vehicle. It is a visual theft deterrent, even if you do not have an alarm. It's normal. The reason the light stopped flashing is because you unlock the vehicle with the remote and locked it with the door switch.
Posted on Feb 11, 2011
Testimonial: "Thanks for clarifying the reason why. The system is brand new to me. Was not aware of that feature. Thanks again."
  • tatipamula
    tatipamula Sep 24, 2012
    Hi Larry, Just installed Viper 5101. I noticed blue light flashing when car is locked using the remote. As per reply that is common. But my question is that is blue light flashing all night, it is eat the car battery. i think car battery will dead if lights are on all night. please advise
  • Larry Spears
    Larry Spears Sep 28, 2012
    No, the flashing blue light WILL NOT drain your battery. The current draw is somewhere near 7Ma, nearly nothing while the current draw for the memory power in your radio may be somewhere near or at 10Ma.
Joel St-George
    New Friend:
I have a 2000 ford taurus bleu light stays on when trying to starte signal lights flash twice what would be the probleme thank u in advance
Posted on Dec 29, 2017
2003 VW GOLF REAR door wont open
The rear door lock actuator has failed in the door locking unit this is a common problem you can manually unlock the door to replace the latch if you didn't have the deadlocking on if you cant try pressing the locking button twice so when the car is locked the flashing red light is not blinking ie off on the drivers. Doing this usually causes the faulty lock to release the dead locking so you can pull the inside handle to unlock the door.
Oct 13, 2016 | 2003 Volkswagen Golf
Audi tt x reg - the key fob is not working. Additionally, the hazard warning lights intermittently come on when i the engine. The hazard warning lights do not stop flashing and i often have to try...
this can be a big problem so will start on easiest first. and try to repair as going, the passenger door the problem with this could be the solenoid for the door lock. and or the switches in the lock. driver door has the same but is the master door. ie if you open door from unlocking at pass door it will only open this door, drivers side will open all doors. flashing hazards this could be because the alarm is not completely turned off this could be because of the doors, mainly the drivers side. try to find the fault with the door lock and get back to me when you have found the fault. you will need a meter to check for volts and the switches, check them as lock unlock from the inside and the key to make sure they working. dpd spray should be able to clean them if you can spray into the lock and housing that is plastic. give a good flush out after its working wipe up the mess from the spray and mear grease on the lock moving parts.
Jun 26, 2017 | 2000 Audi TT
I bought a 1996 Subaru Impreza L 4dr 5speed AWD that runs and starts fine but when I was installing fog lights i noticed that there appears to be an alarm hooked up (it says "code alarm elite DM...
Battery Constant 12v+ Positive Wire (+): Black/Yellow
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Blue/Red
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Red
Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Red/Yellow
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Red
Parking Light Positive Wire Location: Low In Drivers Kick Panel
Power Door Lock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Lock Negative Wire Location: To Drivers Door Only
Power Door Unlock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Unlock Negative Wire Location: To Drivers Door Only
Door Trigger Negative Wire (-): Red/White
Door Trigger Negative Wire Location: In Black Plug, Above Hood Release
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Red/Green
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black/Blue
Tachometer Wire Negative Wire Location: At ECM, Under Drivers Side Dash
Brake Light Positive Wire (+): White/Black
Brake Light Positive Wire Location: At Switch Above Brake Pedal
CODE ALARM SYSTEM
Used on:
Impreza 1996-2001
Legacy 1995-1999
Forester 1998-2000
codealarmremote2.jpgBattery GP-23A
Lock: Left button will lock all doors. Double chirp indicates locked.
Unlock: Right button will unlock driver's door only. Hold unlock button app 6 seconds, it will unlock all doors including rear gate. Single chirp indicated unlock.
If the car chirps or lights flash 4x the alarm was triggered.
Panic. Press both buttons to activate emergency honk and flashing lights.
Valet mode: With optional alarm onlyPress the red alarm button on the left of the steering wheel. The light will quickly double flash. To re-set back to normal mode, press the red alarm light button again
Battery failed and lights flashing?
Parking lights will flash when the vehicle's battery is disconnected and reconnected.
To stop lights from flashing, either:
Press remote transmitter "UNLOCK" button once OR turn the ignition switch to the "ON" position and press programming button for one second (see below).
The vehicle interior (courtesy) light and door open warning light (DOOR AJAR indicator) will then illuminate for 60 seconds when the ignition is turned off, or until the doors are locked with the remote transmitter. Yes, the dashboard instrument panel lights will flash when the parking lights flash.
Programming or Overriding the Alarm when you have lost the remote
Open driver's door.
Turn ignition key to 'On'
Press and *hold programming button* in (see diagram, button under dashboard)
After 15 seconds the the door locks will cycle 3 times. Do not release Programming button.
Press lock (left) button the remotes to be programmed. The door locks will cycle one time. Exit programming mode by releasing Programming button under dashboard and turning key to off.
codealarmremote1.jpgCode Alarm Programming Button is under dashboard on the kick panel by the driver's left knee, left of the steering column. If you can't find it, it might still be tucked up in the wiring harness higher up in that same general area. The botton is recessed in a plastic ring (see diagram).
This button must be pressed while programming remotes or if the battery was disconnected and the lights are flashing.
Jan 05, 2011 | Subaru Impreza Cars & Trucks
RS Focus registered yesterday 19th March Keyless entry but remote fobs do not lock or unlock car. The car was driven back yesterday hav ing now covered 114 miles alarm was going off last night but thats...
should not be using fob buttons for entry or locking for emergency only .if keyless entry walk up to car with fob do not press any buttons see if door opens then walk away from car with fob about 20m then go back to car without fob and see if door locked if so all working fine .indicators will not flash if the above dont work take back to main dealer for diagnostics keys may need to be reprogrammed
Mar 20, 2010 | 2009 Ford Focus
Door locks stoped working
See if there is a fuse for your door locks.
Good Luck!
Sep 15, 2009 | 2006 Chevrolet Tahoe
Camry 1996 automatic power lock doen't work, but windows work.
if you can here relays when unlocking/locking check for power at door lock actuators inside doors, if you have power on lock/unlock and good earth from connector actuators are faulty.
if no power on test light when operating check output from central door lock module while operating, none coming out of module then it might need replacing.
check 30Amp power fuse for main relay under bonnet (which goes to pin 8 white/blue on module)and 10Amp gauge fuse in cab(pin 1 blue/red on module),pin 15 is also power when relay is on(red/blue) with test light, and module/ actuators.
check outputs from module pin 3 & 4
blue/red
blue/black
that go to door locks
Jul 20, 2009 | 1996 Toyota Camry
5301 LE 2 Way Car Remote Starter System Logo
Top Viper Vehicle Parts & Accessories Experts
oneStan
oneStan
 Mikey
Mikey
ADMIN Canada
ADMIN Canada
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
