Question about Price Pfister Universal 0X8-310A Pressure Balanced Rough-In Valve for Tub
I installed a new Price Pfister 08 series tub & shower single control, pressure balancing valve body.The temperature adjustment is set at full travel for temperature. The water doesn't get very hot at the full hot setting.There is a note in the installation instructions that say adjustment gear is factory-set to prevent stem from reaching full hot position. Any solutions? Bad cartridge? Can another type of cartridge that opens to full hot position be installed in this valve body?
Posted by waynesub on
  • Anonymous Mar 23, 2014
    adjusting the temperature
Anonymous
  • 528 Answers
No and you can thank you government rep next time you see or talk to him for this. The valve is set to give no more than 110 to 115 degree water and cannot be changed. If you want hotter water you will need to install a non-scald faucet. Now if you are not getting to the 110 degree mark then you will need to disassemble the valve body and look for debris in the hot water inlet side.
Now when it is apart turn the water on low and flush the piping out before putting it back together.
Posted on Feb 11, 2011
How do I adjust water temperature on a Pegasus shower head?
Adjustment is usually on the valve assembly. Take off the big round trim ring and you will find the adjustment on the valve assembly or in the valve stem.
Oct 19, 2014 | Pegasus F1226700RBP 1100 Series Single...
I need a replacement cartridge # 17196-0100k for a single handle price pfiser shower valve. where can i order one?
I have a single handle price pfister shower valve Model 17196-0100k .No cold water.It's coming hot on both sides.
Mar 28, 2011 | Price Pfister R89-7PC0 Chrome Portland...
The shower tap is broken. The top came off of the plunger that changes the water flow from shower to tap and all the other pieces fell into the tub. Is there an easy way to fix it. I am definitely not a...
it may be very simple--you have to get your head underneath the tub spout and look to see if there is a "set screw" on it---if there is ,you unscrew it, which releases the screw holding the spout in place on the pipe coming out of the wall---jimmy it a bit and the spout will come off---don't yank too hard---if there is no set screw, then all you do is turn the whole tub-spout counterclockwise carefully, and unthread it from the pipe in the wall..replace w/ a new tub-spout--anywhere from $5 to $500
Feb 24, 2010 | Price Pfister 01-111 Shower Head, Tub...
Water leaks out of shower head during tub use. valve was installed properly
The pipe to the tub spout is either restricted or the valve was placedd too high causing some of the water to come up and out of the shower head instead of it all flowing out of the spout.
Nov 12, 2009 | Price Pfister R89-7PC0 Chrome Portland...
R89-7tuc thermostatic valve a little bit cold on temp. adjustment. how can i adjust the settings
Take off the handle and the cover plate usually there is an adjustment under the cover plate.
Oct 18, 2009 | Price Pfister R89-7PC0 Chrome Portland...
I have a Price Pfister Model no. 808 DK00 single handle bath tub/shower faucet. I am only getting hot water coming out when the handle is turned on. This problem just started. It was working fine for about...
It's likely that you have some sediment that has accumulated in the cold water valve and has clogged it. The model number you have cited above is only for the trim (rather than for the valves behind it). Assuming that you have a Price Pfister valve, they don't have built in filters, so you're probably going to have to either clean or replace the valve.
Sep 17, 2009 | Price Pfister R89-7PC0 Chrome Portland...
Price Pfister Shower--No water to shower
Does the tub spout water flow stop when the shower knob is pulled?
Was the systems pipping flushed before the shower head was installed?
It may be clogged, remove the shower head and then attempt to operate. If it is clogged you will see debris trapped in the screen at its connection point. The shower head can be disassembled - cleaned - reassembled
Is the shower head an adjustable type, that may be in the off position?
Good luck
Aduz
Mar 26, 2009 | Price Pfister Hanover 950-102S Soap &...
Swaping Pfister Shower leaver handle
it must be the same model number,most models come in different colors and styles.
Feb 27, 2009 | Price Pfister 01-111 Shower Head, Tub...
Price Pfister Universal 0X8-310A Pressure Balanced Rough-In Valve for Tub Logo
Top Price Pfister Plumbing Experts
Bill Johnson
john h
Mike
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
