Question about Electrolux Frigidaire Affinity 5.8 cu. ft. Super Capacity Gas Dryer
My dryer is making a humming sound when you try to start it,all lights will come on but it will not start, i did a test on it and its showing error code e68, how do i fix this
Posted by mjnichles on
D. Floyd Kolb
  • Electrolux Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Posted on Feb 11, 2011
It will not turn on. When I unplug it and plug it back in the start light is constantly blinking. I checked for error codes and the 4 lights blink 9 times and the start button blinks 14 times.
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Nov 09, 2015 | Kenmore Dryers
Model # GLEQ2152ESO will not start just humming sound when you push start button. Error code rE5
Apr 13, 2015 | Frigidaire Dryers
When I turn my dryer on all the lights light up and when I punch start all it does is hum. What can the problem be?
BAD DOOR SWITCH OR BAD MOTOR WINDINGS?
Sep 23, 2014 | Dryers
Frigidaire affinity LEQ6000ES2 error code e68...dryer will not start
Good Afternoon David,
I understand that your Frigidaire Affinity dryer, model# LEQ6000ES2, is showing you an error code of E68 and will not start. I also see that you have changed the thermal limiter. Looking at what the E68 error code means, a key or button stuck, there could be something else causing the code to come up. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the E68, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire Dryers
Cabrio Dryer not turning on when hit start button
If it makes a humming noise, as if it's trying to start, you most likely have a defective motor.
Feb 26, 2014 | Dryers
Maytag Epic dryer model MED9800TQ0. Dryer was running fine, changed loads, held the start button down, it beeped and attempted to turn the drum, clicked and nothing. All the controls light up, timer...
does the element come on at this point ?
I'm not sure if you tried this already or not, but i would unplug the unit and wait a min and plug it back in and see if it resets and then works again . you could have had a power surge .
Nov 05, 2013 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
I have a kenmore 90 gas dryer modal # 110-77904792, the dryer gets power but wont start when you push the power button, it makes a humming sound?
possible could be the drum motor depending on type of hum. if a motor is trying to start sometimes will make that sound
Feb 09, 2012 | Kenmore Dryers
Dryer won't start after selecting cycle choice. lights are on lint filter is clean.
Does the dryer make a humming sound when you try to start it or is it completely silent?
Jan 31, 2011 | Bosch Axxis WTA4400 Dryers
Dryer won't start. has power, lights are on, when I push start I just get a loud humming sound.
Try to turn the tub by hand, if it will not move or is real hard to turn, your motor may be locked down. They usually make a humming sound when you try to start.
Aug 28, 2010 | GE DPSB513BW Dryer
Electrolux Frigidaire Affinity 5.8 cu. ft. Super Capacity Gas Dryer Logo
Top Electrolux Dryers Experts
Vernon Taylor
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
