We have a Duet Washing machine. It keeps sounding the alarm and then the letter F will show up followed by the letter H..do you have any idea what these warnings mean...it just stops working and keeps flashing the those letters and the alarm sound.
Posted by paul16724 on
Anonymous
  • 4,323 Answers
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hose, it may be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Posted on Feb 11, 2011
Whirlpool duet ghw9200lw front load washer will not start cycle
Check the door interlock on the washing machine. If it's faulty, the machine won't start its cycle. This page will give you an idea of what interlocks look like.
Door Interlocks
Feb 20, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Machine just stopped,alarmed and shows the following code dE, any idea what could be the problem
door sensor need to replace or if you can easy to repair usually plastic part is broken
Nov 06, 2013 | LG WD-1280FHD Front Load Washer
How do I stop my washing machine door alarm beeping?
do this and fix it. God bless you
However read the instr. manual section troubleshooting /
if doesnot have download from www.fitness.manualsonline.com
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Sep 28, 2012 | Hotpoint WMA74 Front Load Washer
go to instru.manual section troubleshooting and fix it. God bless you
if doesnot have it download from www.fitness.manualsonline.com
However try this.
Sep 28, 2012 | Hotpoint Ultima WF860 Front Load Washer
I need a parts manual for a whirlpool front loader washing machine
Please go to the following link and download the manual. It is for GHW9100 and quite exhaustive showing all the pars and their assembly.
http://applianceassistant.com/pdf/duet.pdf
Sep 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The machine won't sart. the code seems to be an L , followed by an F duet GHW9150POW the timer sounds to be running & cycle sset to cold/cold w/ only cold water hooked up. cycles briefly through...
If that is a new unit the hot water has to be hooked up as it will take in a small amount of hot water even on the cold cycle. whirlpool strarted this a while back due to energy use..try hot water let me know.....good luck.........
Jan 31, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Sounds like rocks in my front loading washing machine
did you try removingthe lower acess panel and checkin g the drain pump for possible obstruction??
Mar 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
HF alarm
1st ck all hoses and screens for blockage be sure you have good water flow to washer next remove top ck flow meter left side 2 small hoses 1 in one out may be able to tap it on the side and temporaily correct problem best bet is to replace it
Oct 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Steady tone coming from ghw9150pw0
could be problem in control bd not necessarily a problem with function but something in sound circuit ck for a sound control button on keypad it may say something like alarm volume or on off try holding it down after turning power on if you notice any change in volume or tone of sound shows you're on right track only thing is solution may mean new control bd
Sep 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
