Question about RCA TruFlat 27F520T 27" TV
I dropped the remote to an RCA TruFlat HDTV on a vinyl covered, concrete floor. It no longer works to change the input (or anything else), especially to switch between the TV and a Wii. Can the remote be replaced and if so how, where and how much?
Posted by rpiper904 on
Anonymous
    Novelist:
  • 117 Answers
At the following website you can order a replacement remote for your TV
http://www.replacementremotes.com/store/prodthumbs.cfm?ns=1&keyword=27f520t&category=All+Brands%2FType+brand
Either one of the 2 pictured remotes are acceptable replacements.
Click on either picture for details as to how to order, cost, and shipping.
Posted on Feb 11, 2011
I have no remote for an rca l32wd22 hdtv lcd tv and cannot find the inputs to change to HDMI?
Unfortunately, the L32WD22 doesn't have an Input button on the front panel of the TV. You need a remote control that matches the Input code for the remote. Here's one link to a remote that should work: http://remotes.com/store/rca/l32wd22.html . Other universal remotes may work if you find the correct code if the remote has an Input or Source button.
I hope this helps.
Apr 16, 2013 | RCA L32WD22 32 in. LCD HDTV
How can i change the video input on my rca truflat tv 27F520T without the remote
As there is no Menu button on its front panel. you can't select inputs to this TV without a remote control.
Jun 05, 2012 | RCA TruFlat 27F520T 27" TV
Rca truflat tv with univsersal remote. attempting to change input to view dvd but no input button on remote. Is there an alternative
Look for a "source" button, if you do not find one, just try scrolling through the channels as some TV sets will cycle through inputs after you cyucle through channels.
May 05, 2011 | RCA Televison & Video
I have a 19 or 20 in rca truflat and cant figure how to make my dvd work. i have the cables in line out on the dvd and line in on the tv. is there a way to change the input, ican not seem to find a way.
should be on the remote should says Input or Source
look at where you plug in the devices, should say Video 1, 2 ,3
Then use remote to put on the right input sources.
Also make sure you have the RCA cable connected properly, not all cables works some can be broken, make sure they are new.
good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Apr 13, 2011 | RCA TruFlat 27F520T 27" TV
I have a rca truflat tv but lost the remote. How do I get to the input "channel"?
You can usually purchase an RCA universal remote at a discout mall. Just be sure your new RCA remote has an input button! The older models made in 1993 and 1994 would require you press 00. Not so on the newer ones. Good Luck and thanks for asking!
Jun 23, 2010 | RCA TruFlat 27F520T 27" TV
How do you unlock a rca truflat tv?????
Check out remotes.com or simply buy a universal remote at wal-mart walgreens, radio shack.......
The original remote is no longer available for purchase. http://www.remotes.com/remotes/servlet/rs?uuid=12445202934080&o=c&o=c&a=Search&uid=0&m=20F511T
Sep 09, 2009 | RCA TruFlat 27F520T 27" TV
I need to know the Unaversial remote code for the television
  • Hi, thank you for visit fix ya.
You can buy any universal remote control.
Also, you can find RCA universal remote control ( don't need be program, just install battery, and is ready!!. Press input for DVD or game).
Thank you
Jul 25, 2009 | RCA TruFlat 27F520T 27" TV
RCA TruFlat 27F520T - FPA on and NO REMOTE
If you've lost the original remote there is nearly no possible way to unlock the unit. RCA built their PL so that the combination could be set and the parents would merely have to take the remote with them and it couldn't be changed...
As to the DVD I don't believe there is an input button on the face of the unit and I'm not real sure if you could find a universal that would allow that... Not even Miracle remote makes an alternative and their remoted are as good as the originals...
Sorry
Bill
Feb 03, 2008 | Televison & Video
RCA TruFlat 30-something inch
what chassis is in your set.look on rear panel ./st
Dec 09, 2007 | RCA 32F530T 32" TV
RCA TruFlat  27F520T 27" TV Logo
Top RCA Televison & Video Experts
Paul Bade
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
