Question about Sony Handycam DCR-TRV510 Digital Camcorder
I haven't used my DCR-TRV510 for awhile. Now, when I try to playback one of my pre-recorded tapes, the video and audio are choppy. I wanted to do some video work with iMovie, but not with this problem. Any suggestions about what could be the problem?
Posted by Russ Tardif on
Rick J Riggins
    Genius:
  • 1,812 Answers
This is usually caused by an oxidized or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Feb 11, 2011
5 Related Answers
Anonymous
  • 73 Answers
SOURCE: Hi8 playback problem
your guides have come loose , probably - the digital sound will be next to go because the bottom edge of your tapes are being folded - open the cassette tape lid by pressing the small pin near one hinge and gently lifting the door - if there are any creases ? get the guides aligned ! to protect your library ; ( if there are no creases , try a sony d8 cleaning tape - once ! before getting a repair quote ) ;
Posted on Jul 29, 2007
Anonymous
  • 317 Answers
SOURCE: imovie imports Hi8 tape but not plain 8 tapes
What it is, is the standard 8mm tapes are not digital, and therefore won't import into imovie, unless you have the 8mm to Hi8 option enabled in playback mode, by setting it in the menu, under playback settings.
Posted on Feb 21, 2008
Anonymous
SOURCE: Playback is choppy
I had this problem very recently. In fact I borrowed camcorders from my friends too and after short periods, they too started having the same problem. Essentially, it looks like there is some choppiness every second or so - like there is noise in the audio and video. After a lot of looking around, I finally found a suggestion posted that ACTUALLY WORKED on all 3 camcorders:
I placed an empty tape in the camcorder and recorded a few seconds into it. Then I removed that tape and tried to play the previous tapes that were showing the choppiness. No problems any more. Everything works fine.
What I still do not understand is why 3 camcorders (all DCR-TRV103s) all showed the same problem (with different tapes by the way). And since I still have lots of tapes to copy, I need to know why this problem is happening so I can minimize its occurrence while I complete the copying process.
People have suggested that my tapes are old and may be offering resistance to the camcorder. So I have ordered a rewinder to spin the tapes a bit before trying again. The two possibilities suggested around this was (1) some mechanical switching took place which got reset when recording; and (2) something got corrupted in the software that manages the playback buffer and that software was rebooted when it went to recording mode.
So while this will hopefully answer your question, I'm also looking for explanations for why this happened to me on 3 different camcorders.
Posted on Mar 18, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: playback choppy
Camera needs Tape Path adjustment and qualified camera tech person can do the job.
Posted on Nov 06, 2008
Anonymous
  • 107 Answers
SOURCE: sony DCR-TRV510 error code C 31:10 tape bay closes then opens
The error code was indicated the LS chassis assy is defective, bad luck it require a qualified Tech trained from Sony. I suggest you to bring it in Sony to repair it would cost you about from $180 to $250 if you are in AUS
I hope that give you some ideas
Posted on Dec 04, 2008
No playback pics. Blue screen.Can't record.Used x2 since service.
I just made contact with a service tech who seems very competent and who won me over. Have problem with video and audio dropout similiar to dirty heads on a 10 year old DCR-VX2000 but which is a larger problem attributed to worn parts which will need replacement. Do not know how old your unit is, but will share name of person/company if you wish. Only thing that worries me is if you by chance had had yours repaired by them!!! They are a Southern California company.
Jan 27, 2009 | Sony DCR-VX2000 Mini DV Digital Camcorder
Sony DCR-TRV510 Playback Blank or Choppy
I recently had similar problem. Sony Phone tech support was very helpful. The answers were strange. You need to make sure the cameral is turned off, unpluged and take the battery out for at least 5 minutes. (something to do with reseting firmware). That sort of worked when coupled with there last comment which was to RECORD about 15 seconds and play it back. Mine was instantly healed!
Jan 13, 2009 | Sony Handycam DCR-TRV510 Digital Camcorder
Video playback displays mosaic patterns when the camcorder is moving or quickly zooming in or out during video recording. Stationary videotaping does not display the mosaic patterns during playback.
Digital camcorders use compression algorithms that allow them to "cheat" or squeeze the very complex video signal on to a small tape in a short amount of time. When you zoom or pan quickly, each frame is completely different from the one before and the little internal computer can't keep up with the images. It does what it can in the amount of time it has and what you see is the shorthand version. The only solution is don't move the camera fast or buy a new camcorder which will have a faster internal computer.
Dec 29, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Sony DCR-TRV510 error code C 31:10 tape bay closes then opens
Dec 04, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Playback choppy
Nov 06, 2008 | Sony Handycam DCR-TRV265E Digital...
Hi8 Playback Compatibility with Digital* Camcorders
I believe all Sony model DCR-TRV2XX and 3XX would play Hi 8 and ST8
Such as DCR-TRV265, DCR-TRV285 DCR-TRV340, DCR-TRV355
Aug 01, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Sony TRV510-playback, audio choppy, image isn't clear
I was having the exact same problems, and I read a post on this website somewhere recommending that I just record a few seconds of video on a blank portion of tape and then the camera should start playing video normally again.
I tried it, and IT WORKED!!
Jul 15, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Sony dcr trv 510
I think you face this digitizing problem in old recorded cassettes.
If yes, your camera needs little adjustments of tape guides. There will be one guide lose. In technical, we call it Tape path adjustment.
Jun 01, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Setting the tape speed
Power up camera on Camera mode, go to menu, select camera settings, go to Record Mode and select SP or LP there. Now your camera is ready to record as per selection.
You can not change speed SP/LP during playback mode because its properties of signal set during recording.
Mar 15, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Playback is choppy
Oct 05, 2007 | Sony Handycam DCR-TRV260 Digital Camcorder
Sony Handycam DCR-TRV510 Digital Camcorder Logo
Top Sony Video Cameras Experts
Jax Planet
Jax Planet
Nasir Muhammad
Nasir Muhammad
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
