Question about Bose Lifestyle 28 Series III DVD Home Entertainment System - White
WHY DOES DVD HAVE SPLIT SCREEN ON BOSE DVD - Bose Lifestyle 28 Series III DVD Home Entertainment System - White
Posted by nathanielash on
DVD player is black and white and screen is split
Make sure the player is compatible with your TV broadcast standards. A Pal player will show b&w pictures when connected to a NTSC tv and vice versa
Feb 26, 2015 | Samsung DVD-V3500 DVD Player/VCR
I have a bose acoustomas system. It does not have HDMI inputs on the bose amp which denies me hooking a blu ray dvd to the system to access sound for the speakers thru the amp. I want to have dvd and hdmi...
Simple.Depending on the number of HD gadgets you have,you need either 2 or 4 channel HDMI converter.Connect the HDMI output to your tv and connect other equipments to the various HDMI,VGA,component and composite inputs,including your Bose System.
Dec 04, 2013 | Bose Audio Players & Recorders
Dvd player is playing a vertical split screen
If the TV does the same with two different DVD players, it must be a menu setting on the TV. Look through the TV menu options.
Jul 24, 2013 | Panasonic DVD-RP56 DVD Player
Hello, i have a vizio flat screen tv and i don't know the correct places to connect the cables of my Bose Lifestyle 48 Series IV DVD Home Entertainment System. Please help me
Does the Bose have HDMI out? Does the tv have an HDMI socket?
If it does just connect them both together. All inputs i.e. cd, ps3 dvd etc will go into the Bose.
Aug 09, 2009 | Bose Lifestyle 48 Series IV DVD Home...
Bose lifestyle 48 dvd black and white only
Go to the "Bose" menu screen viewing on your TV (make sure no dvd is in the player) Go to your Video controls and check your output, chances are, if your using the component output your player is set to "S-Video". Should fix the problem. Hope this helps. If it's still not viewing correctly, post a comment and I will help you some more
Jul 26, 2009 | Bose Lifestyle 48 System
I have Bose 321 system w/ DVD player. I connected RGB cables directly from Bose to LG 42 inch flat screen. When i play a DVD, the image is in b&w. How can i get color?
That happened to me---there's something loose in the jacks leading out of the Bose to the TV. I thought it was just mine. You just have to jiggle them and you'll get color. That really sucks.
Jun 14, 2009 | Bose Cinemate Digital Home Theater System...
Memorex dvd player pscan split screen
I had the same problem with mine. I flipped the switch on the back and it worked instantly, hope yours does too.
Feb 26, 2009 | Memorex MVD2042 DVD Player
Connecting ipod to bose system
Look at the back of your 3-2-1 to see if the auxillary is a single or dual output. You will need that information when you go to Radio Shack, or you can also get at the Apple store, a connector from Gigaware that connects to the ipod. It was only $15-$20,
Jan 04, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
JVC DVD player stuck in Split screen
the player is set to progressive scan mode.use relevant button on remote to reset to interlace mode. Duane,S/Africa
Mar 11, 2007 | JVC XV-N320 DVD Player
Bose Lifestyle 28 Series III DVD Home Entertainment System - White Logo
Top Bose Audio Players & Recorders Experts
Harrie
Falling star
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
