Question about Sunbeam Microwave Ovens
Sunbeam Cafe Series EM6900 Yesterday I think I ground the beans a bit fine, the machine pressured up but not into the red on the guage. The coffee was trickling then water started coming from around the group head. Took out the goup head seal and found it was split. Rang local repair agent who said he had one in stock but couldn't do the job B4 the weekend. As I have a whole lot of guests for the weekend I elected to replace this seal myself. So far I have had three goes at it and the result is always the same. Group head fitted with filter cup in place, no problem. As soon as coffee is added to the filter cup I get water pouring down the sides of the group head and diluting the coffee. What am I doing wrong? There appears to be only one way to install the seal and filter plates.
Posted by lindsay_sand on
  • lindsay_sand Feb 11, 2011
    You do not appear to have got the picture. Plain water flowed very well from the double spout with the filter basket in place it was only once I added the coffee that clean hot water flowed down the sides of from the top of the group-head. I have pulled all the bits out of the group-head as you instructed, cleaned and reassembled it. It was relatively clean and undamaged
    Look I tried bought ground coffee as well as my own grind. I have tried a smaller amount of ground coffee all with the same result. The machine has cooled and there is no coffee residue between the filter basket and the group-head or on the outside of the group-head.
    Since our last communication I finally managed to get hold of a friend who I remembered had a similar problem with his coffee maker. He said it was possibly the neoprene gasket between the the seal and the main body above the group head assembly. I cant do anything about it now so I am stymied till after the weekend. So thanks for your efforts but the time is now 1620hrs in N.Z. and I am running out of time to devote to this cause.
raj somaiya
  • 5,370 Answers
Remove the black plastic thing from the filter basket.Check if that is cracked or broken.If its broken replace it,other wise remove it and clean it internally also clean the head gasket.:---It is held in by a little retaining clip. To get it out without damaging. Remove the spout (use a screwdriver wrapped with masking tape so you don't damage the spout...then use the screwdriver to leverage off the spout). Once you have the double or single spout off...get in there with a screw driver and pop it out! See fig below:-- Sunbeam Cafe Series EM6900 Yesterday - helpmech_72.jpg its purpose is to insulate the pouring espresso from the portafilter, keeping it hotter. -------------
Remove the retaining clip for the basket with the tine of a table fork - easy!
- Remove the spout - you can use a screwdriver to loosen the double spout.
- A techscrew driver bit will be useful,It just needs to be something hard and cylindrical you can hit with a hammer to knock the plastic liner out. A bolt with an appropriate diameter would work fine.
- Placed the group head upside down on the carpet (to avoid scratching it on a hard surface) and give the driver bit a tap with a hammer whilst holding it against the bottom of the plastic liner.. It pops out with the tiniest of taps (and undamaged )
This is how dirty it gets/.Remove this and clean it and also check if its damaged:--See fig below:--
Try this cleaning and checking.This will help.Thanks.Keep updated.Helpmech.
Posted on Feb 11, 2011
  • raj somaiya Feb 11, 2011
    Ok,you mean to say that simple hot waster flows and comes out properly,with out any problem.But when coffee beans/ground added, at that time the water flows from top side of the group head.In most cases this problem is due to seal.Recheck if the seal is connected properly.I agree you have got the seal replaced and you have fitted it properly,but still once again inspect the seal.Ok seal fitted properly,confirmed then check the coffee grounds,are they getting filled too much,if yes fill bit less then see.If they are filled properly,then check if they are bit thick ,that coffee grounds getting stuck in between and causing block in filter and this cause water to flow from its sides.Grind the coffee ground manually in a mixer then fill it up and see,if that is making any difference.----------------As soon as you see water coming from top of the group head,turn the coffee machine off from mains,unplug it then wait for machine to cool down and then see the coffee grounds,are they getting stuck-up and causing coffee to come from side instead of filter.----------Keep updated.This should help.Thanks.Helpmech.
Coffee is not coming through spout. Water just builds up and when switched off it flows into drip tray. Coffee machine bought new just over a year ago. Freshly ground coffee beans being used at the correct...
The water valve has failed - the internal shaft that moves the flap was sheered off. The valve would have to be replaced by a dealer or certified repair shop - they are the only ones with access to replacement parts.
It will be expensive so ask an estimate before accepting the repair - it might be cheaper just to sell this one for parts and get a new one.
Aug 21, 2011 | Microwave Ovens
We have a 12 cup Mr. Coffee about a year old. We put 4 scoops of coffee in and the appropriate amount of water. Every day, the filter overflows and grains of coffee get into the pot. How do we keep this...
Because I own a espresso company,I believe I can help you. There is several things that can cause a coffee machine to over flow. 1, putting to much coffee in, where water can not drain through filter. 2. The grind of the coffee, if it is ground to fine, like ground for espresso, will not allow coffee to flow through filter , drip machine that are not under high pressure like espresso machines have to have ground more course. 3, wrong type of filters, not fine enough for water to flow, or made for high pump pressure machine such as espresso machine . 4, putting to much water in, is not an issue on a mr coffee, because even if you fill it to full cup line, it would have nothing to do with filter over flowing, besides the coffee grounds always absorb some of the water anyway. In conclusion, my positive professional diagnose is Grounds of coffee to course, and 4 scoops seem a bit to much for a filter of a mr coffee machine that holds only 12 cups. To test this is make a pot same way and use only two rounded scoops and see what happens, if does not over flow that solves that. But your saying I want it stronger, believe me I know. I too like my coffee strong and a flavorful . I have that solved too. Go to a good walk in espresso shop, like a star bucks, tell them you want some good strong blend and have it ( Ground for Drip) and then still only put two rounded scoops, it takes less do to the blend and kind of coffee. Please let me know if my advice worked, thanks mike. oh notice my screen name of mc1 bean, now you know, I know what I am talking about :)
Jun 07, 2011 | Microwave Ovens
Working instructions not included would love to be able to use my new cafe series coffee machine purchased yesterday in WA at Rick hart
hello lyn... go to this link http://www.sunbeam.com.au/Pages/Browse/ProductDetail.aspx?pid=1136
just below the picture of the machine, click on "manual pdf" and you will have a free download of the instructions you are seeking. Joe
Thanks for choosing Fixya!!
Mar 06, 2011 | Microwave Ovens
My Sunbeam coffee machine model EM900 twin thermolock cafe series.Was leaking water around group head . Have replaced the grouphead seal but still leaks infact worse My machine is 7yrs old but in good...
I have a Sunbeam twin thermoblock Im having trouble with my steam wand I im not getting much steam out for the milk to warm up try to clean it with a pipe cleaner can you give me an advise how to get it woking
Feb 01, 2011 | Sunbeam Microwave Ovens
I need to replace the top that goes over the coffee bean holder on my Capresso 451 coffee machine. This is the old machine that grinds the beans and then makes the coffee. Where can I find this part
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service, and Installation Instructions as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 30, 2010 | Microwave Ovens
Delonghi cafe firenze coffee machine manual
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, and a list of Dealers for spare parts, as required.
I hope this helps.
Dec 26, 2010 | Microwave Ovens
I am looking for a user manual for a russell hobbs cafe continental 3344
Well you may please follow the link below to get your manual -
http://www.trademe.co.nz/Home-living/Kitchen/Tea-coffee-making/Coffee-machines/auction-236701780.htm
Good Luck!
Thanks for using FixYa!!
Oct 26, 2010 | Microwave Ovens
Jura E8 beans will not pass through grinder resulting in "Fill Beans" error message. Saw reference to Kaffeestudio.com for dissasembly instructions but that link no longer works. I assume that the chute...
It seems withthis model you have a 1 year or 4000 cups warranty with this.
If you are within this, then give them a call - here is the Manual if you don't have it -
MANUAL -
I suggest you start by removing the beans in the hopper and wiping around to remove oils.
Then refill with fresh dry beans.
Plug in and set up as normal
Set to brew a standard large cup - and adjust grinder to coarse setting while grinding.
Do not adjust with grinder quiet - it must be done while rotating.
Make at least 10 cups this way at the coarse setting.
I think what has happened is that damp beans (frozen or cold) have entered the unit and caused the coffee to gum up at the top of the burr.
This will just push fresh beans out of the way instead of starting to grind them.
If you use dry (light loast) beans, it doesn't seem to happen as much.
Just ake sure you refrigerate most of your stocks, but keep a small stock at room temperature in an airtight tin to prevent this kind of thing.
You can actually push down on the bean stack slightly with a wooden object while the grinder is running if nothing moves on the coarse setting to get things moving.
Feb 10, 2010 | Microwave Ovens
Microwave Ovens Logo
Top Sunbeam Microwave Ovens Experts
Alan Matzke
Alan Matzke
Paul Bade
Are you a Sunbeam Microwave Oven Expert? Answer questions, earn points and help others
