Question about Nintendo DS Lite Console
My web security does not support nintendo ds - Nintendo DS Lite Console
Posted by whitfieldjoh on
Anonymous
    New Friend:
  • 61 Answers
The DS lite only supports WEP encryption. The only way for you to fix your issues are to change ypu wireless encryption to WEP.
Posted on Mar 03, 2011
Why does my dsi have the error code 0520001
It appears that the security settings entered into the Nintendo DS are not the same as what your wireless router is set to allow, or your router is not able to assign the Nintendo DS an IP address.
How to fix: Make sure the security key and security type are entered into the Nintendo DS exactly as they appear in your router's settings; manually assign an IP address to the Nintendo DS.
Ds lite wi fi connect wpa
Try changing your WiFi encription to WEP or no security, this should be available on your cablemodem/router web internface (need a user and password for that) under the Wireless/Security option.
DS Lite is not compatible with any other WiFi encription for online gaming: "Important note about the Nintendo DSi and WPA security: While the Nintendo DSi is compatible with WPA security, Nintendo DS games with online play still require the use of WEP or no security to connect with the Nintendo WFC. Therefore, your connection settings for using these games must be set up on slots 1-3. If you need more details on using your adjusting your router's settings,click here and select your router (if available).
I'm trying to get wi-fi on my nintendo ds but it keeps saying the access point's security settings are no supported by the nintendo ds.
You need to change the security settings on your router from WPA to WEP. WPA security is not supported by DS. Go to your router's wireless page and under security, change the settings.
Cannot login to internet-code 051100-1
If you would like to utilize the online features of Nintendo DS games, you will need to change the security to WEP or no security. Nintendo DS games are not compatible with WPA security.
If you would like to stay with WPA security, you will need to used the advanced settings in your Nintendo DSi.
Please visit the following page for more information:
http://www.nintendo.com/consumer/wfc/en_na/ds/wrWEPkeyHelp.jsp
I dont know how to set up the nintendo wi-fi connection
  1. At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
  2. Tap "Connection 1 None."
    emptyconnections.jpg (Don't see "None" for Connection 1? To ensure any existing settings don't interfere with getting connected, tap the button, then choose "Clear Settings.")
  3. Click on "Search for an Access Point."
  4. The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
Once you have done this you may find next to your wi-fi, a lock this is what they mean:
unlocked_g.png No security - Your wireless network is unlocked.
  1. Tap on your network name to select it.
  1. Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test with your wireless router.
  • The connection test was successful - Your Nintendo DS is now connected online and you can enjoy the Nintendo Wi-Fi Connection features of the game!
  • The connection test was not successful - If the test was not successful, you will receive an error code.
    • Error Code 51300: This means the security code or network name entered into the Nintendo DS is not the same one the router is set to. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
    • All other error codes: Try our error code lookup where we have detailed information on many common error codes.
wep_g.png WEP security - Your wireless network is secured with WEP and requires a security key.
  1. Enter your router's WEP key into the Nintendo DS Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands Enter your WEP keyOn the upper screen you will be informed that "A security key is needed to connect to this access point." Enter your security key by tapping the empty field, and select "OK" when finished.
wpa_g.png WPA security - Your wireless network is secured with WPA and requires a security key.
The Nintendo DS and Nintendo DS Lite are not compatible with WPA security. If you would still like to connect your Nintendo DS online, you will need to either change your router's security to WEP, or disable security entirely. Please note that any changes you make will affect other devices that connect wirelessly to your router.
The access point's security settings are not supported by the nintendo DS
This means you've got a WPA/2 security connection on your router/access point, whereas the Nintendo DS only supports WEP or open encryption.
You can:
1) change your security from WPA to WEP on your router
2) Purchase a used nintendo wifi stick
3) Set up a second router or access point with WEP security specifically for your DS
2answers
My internet says the access point's security settings are not supported by the nintendo ds. for help visit support.nintendo.com. that is what it says.
Hi weigels,
I see you are getting an error security settigns not support by your Nintendo DS.
I beieve that you are trying to access a wireless connection using your Nintendo DS, the error that you are getting is actually an error saying that your Nintendo DS can detect the router but since your Router has a Network key you then get the error security settings not supported.
for a Nintendo DS it does not support Router settings that have a network security on it, you will have to disable the Routers Network security for you Nintendo DS to be able to access the wireless network of your Router, this will also prevent your Nintendo DS from getting the error security setting not supported.
Note: disabling your Network security will open your Routers signal to anyone who can detect the signal.
I hope this helps.
Have a nice day,
mvincentc
1helpful
The access point's security settings are not supported by the Nintendo DS
WEP and WPA are types of security that are used to protect home wireless networks. WEP is the only security setting that works with the Nintendo DS and Nintendo DS Lite. WPA and WEP are both compatible with the Nintendo DSi. If you are not sure how to find your router's WEP or WPA Key or if you have problems entering it into your Nintendo DS, try the following tips:
so if your wifi is WPA. you wont be able to use wireless
but if your wifi is WEP you can.
WEP is not recommended because it is not secure. Easy to hack
Error code 051100-1
Web setup
With a Wi-Fi compatible game inserted into your Nintendo DS, access the Nintendo Wi-Fi Connection Settings screen. Your game manual provides information on how to do this for the game you are playing.
  1. Tap Nintendo Wi-Fi Connection Settings
  2. Tap one of the Connection slots
  3. Tap "Search For An Access Point"
The Nintendo DS will then display the name of your wireless access point.
If your Access Point has a blue, unlocked icon, tap the Access Point name, and then 'OK.' The Nintendo DS will then establish a connection with your router. Back out to the main screen of your game and your ready to play online.
If your Access Point has a red, locked icon, the Nintendo DS has detected WEP key security on your router. Tap the Access Point name on the Nintendo DS and then enter the WEP key for your router on the following screen and tap 'OK' to save the settings.
Tap 'OK' again and the Nintendo DS will then establish a connection with your router. Back out to the main screen of your game and your ready to play online.
If your Access Point has a gray, locked icon, the Nintendo DS has determined your router's security settings are not supported by the Nintendo DS. In order to connect to the Nintendo Wi-Fi Connection, you will need to either switch to WEP security, or remove the security setting of your router when connecting with the Nintendo DS.
NOTE: All information taken from http://www.nintendo.com/consumer/wfc/en_na/ds/connect.jsp
Nintendo DS Lite Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Aron
WTF Chuck.....
WTF Chuck.....
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
