In hd the picture is curved on bottom and top
Posted by starman620 on
Anonymous
    New Friend:
  • 35 Answers
Is there a place for you to change the format of the tv,ie: zoom, standard, stretch, etc?
Posted on Feb 10, 2011
The picture is curved at the top and bottom and it blury
its good that you give it to an expertise to handle it.....but if u insist and costly, open the back cover, their should some adjustments keys their that helps in adjusting images...one for the 3 colour (blue,Red,Yello) and one for sharpening pictures (making it clear)....for safe use give it to an expertise to minimize further faculties
Picture curves in @ top and bottom and color convergence is off. was fine yesterday.
There are bad solder connections on the flyback transformer and there is a small fuse open. Pretty hard to do yourself but a professional can do this easily.
Curved in at top and bottom and rainbow colors on bottom
REPLACE ALL STK?????? CONVERGENCE AMP IC'S & CHECK RESISTORS FOR THAT CIRCIUT
Curved picture at top and bottom
if it is bowing from top and bottom your looking at a convergance problem if you keep using your tv soon there will be no picture at all when the board crashes... convergance board needs to be replaced... hope this helps..
2answers
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
RCA Projection TV model #p61926
The convergence circuit is your problem and most times with this model the convergence power supply bd. is the problem.
2helpful
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Open Questions:
Televison & Video Logo
Top Televison & Video Experts
Lawrence Oravetz
