Question about Vtech V.reader Animated E-book System
My sons vtech storio has no sound. The batteries are new and have been replaced, the volume is up and the music setting is on - there is just no sound at all. Its very frustrating.
4 Related Answers
reyjoshua07
Reynaldo Labaguis Jr.
  • 1157 Answers
SOURCE: Brand new storio wont turn
Hi lrigney,
If the unit won't turn on, it is often caused by an electrostatic discharge. The easiest way to correct this is by resetting the unit. Please follow the steps below.
You can reset the Storio by:
1. Removing then replugging in the adaptor.
2. Then press the ON/OFF button again.
3. Remove the USB cable, reinsert the batteries and adaptor.
4. Replug the USB cable.
5. Remove any corrupted files and restart the downloading process.
Hope it helps.
Thank you for using FixYa.
Posted on Jun 24, 2011
sophie s
SOURCE: my son's vtech storio's touch
my sons v tech storio wont turn on and im using rechargble battries can some please help
Posted on Dec 31, 2011
pauldenet
SOURCE: Vtech storio not switching on when new batteries
Only had product for two days.when turn it on
a blue screen appears and nothing happens.cant turn it off
Posted on Jan 02, 2012
harfang11
Xarran
  • 13 Answers
SOURCE: i got a vtech storio reader worked at 1st now is blue screen cant turn it of have 2 take batterys out have cleaned it and has new batterys
The blue screen seems to happen when you change the batteries (it's what happened to us). The blue screen indicates that there's a software problem, like when you boot up your computer and for some reason it freezes up. That software needs to be reinstalled. You'll lose anything that was saved on the v.reader, but at least you'll get it working again.
vtech could have made it a very simple problem to solve just by adding in their customer support: Blue Screen? follow these steps. But they don't, so here's how:
You'll need an SD card with at least 64mo of free space. If you want to use the one from your digital camera, transfert all of your pictures to the computer. Everything on the SD card will be erased.
Download the Recovery software from either link below (you can find both on the vtech website)
For the US version
http://contentcdn.vtechda.com/vtechkidsDownload/US/VReader/Tool/Recover/US-engRecoverCardTool.exe
For the Canadian english version
http://contentcdn.vtechda.com/vtechkidsDownload/CA-eng/VReader/Tool/Recover/CA-engRecoverCardTool.exe
This is the link the the website page itself:
http://www.vtechkids.com/download/ca/en
Run the program and follow the instructions (at least those are clear and easy to follow). Mine worked fine after that.
Hope that solves your problem.
Posted on Jan 24, 2012
The touchscreen of my sons vtech storio wont work, even after calibration? he only got it yesterday for christmas!
connect your toy to the Learning Lodge. Go to Calibrate Touch Screen option....make sure that you are also using fresh batteries.
Storio vtech
Are you using a memory card? You need a memory card for this.
4answers
My Vtech V-reader freezes on calibration screen
I just found a solution to this: Turn off the vreader, then press & hold the help "?" button. While holding the "?" button, press power. My system bypassed the calibration step and booted correctly.
17helpful
4answers
Vtech storio in touchscreen calibration mode
Hello I buy my son the V.reader for christmas the next day it say Touchscreen Calibration Utiliy, Touch crosshair to calibrate I need help
3helpful
2answers
How do i fix my vtech storio the screen is just blue and it wont work ?
The blue screen seems to happen when you change the batteries (it's what happened to us). The blue screen indicates that there's a software problem, like when you boot up your computer and for some reason it freezes up. That software needs to be reinstalled. You'll lose anything that was saved on the Storio, but at least you'll get it working again.
You'll need an SD card with at least 64mo of free space. If you want to use the one from your camera, transfert all of your pictures to the computer. Everything on the SD card will be erased.
Download the Recovery software from either link below (you can find both on the vtech website, but it took me a while to get there)
For the US version
This is the link to the website itself:
Run the program and follow the instructions (at least those are clear and easy to follow). Mine worked fine after that. And since there's no reset button on the Storio, this is the only way to erase the 100+ drawings that your child saved.
Hope that helps
13helpful
18helpful
2answers
Vtech storio not switching on when new batteries or plugged in.
15helpful
3answers
It keeps saying touchscreen calibration utility touch crosshair to calibrate. we'v done everything that we could to fix it. it will not go back to the page with activities.
I need help I buy my son V.reader for Christmas it say Touchscreen Calibration Utility Touch Crosshairs to calibrate. I need help? how do I fix it?
3helpful
Vtech whiz kid learning system has no sound. can use it with the pc, however; takes 15-20 times trying to turn on the unit before the software recognizes it is on. Tried resetting unit...new batteries (3...
My son has a year old Vtech laptop and I can no longer get sound from it. Have replaced batteries but that has not solved the problem. Can anyone help?
Jan 06, 2010 • Vtech Toys
Vtech V.reader Animated E-book System Logo
Top Vtech Toys Experts
tina gallow
GI Consulting
Amos McRee
Are you a Vtech Toy Expert? Answer questions, earn points and help others
