SOURCE: Uploading Camtasia video to web page
If you are using a Flash then you can create your own flash play, pause, stop and exit button by flash using action script so that when you upload video through website it will work. if no idea with action script then refer to this site www.actionscript.org .... Thank you
SOURCE: camtasia video capture = black screen,
I will not be back to your service. Your 'smilemaker' expert was rude, succinct, had no idea how to solve the problem and gave me a bad taste in my mouth. I have since identified the problem to be one of Direct X variety which is not working correctly in the register.
SOURCE: Extremely slow to update changes on timeline...
This is a known issue when too many edits are made. Supposedly Camtasia Studio 6 (recently released) will decrease your editing time by 30%. I have not been able to verify this yet. The best way to resolve the issue is produce what you have as an AVI and start editing that, and so on, and so on.
SOURCE: Memory Problems
The clip can be recovered if you open the temporary directory where
Camtasia stores the raw captures in AVI format. The path to the
temporary directory can be found by opening the
Camtasia Recorder > Tools > Options > Program > Temporary
file folder (I'm using v.5 so it may be a little different in other
versions).
I've found that there's a certain workflow that seems to work best and
you can avoid accidentally erasing your temporary files and having to
start your capture session over from the beginning...
Good luck - We've had the same trouble here and we use Camtasia almost
everyday. In my experience, this seems to happen more frequently when
we capture larger dimensions - especially if the capture contains full
motion video (as opposed to just screen captures of a product demo or
something) and we always seem to have trouble when capturing things
that play back FLV or SWF clips at a higher bitrate. This issue is
also described in TechSmith's Camtasia knowledge base.
