Question about NEC MultiSync LCD1512 Monitor
How do i buy the neck that hole the monitor to stand
Posted by lmoore38889 on
graeme ian hunter
    Genius:
  • 1,288 Answers
Contact the manufacturer, they will supply one for you
Posted on Feb 10, 2011
Can we remove stand from monitor HP 2010i
Dear yes you can remove stand of HP monitor with the unlock behind the monitor near stand neck.
Thanks
Firoz Ali
1helpful
Where can I buy a new base for the Samsung 24
The original Samsung stands will be very hard to find, only available from somebody that has wall mounted their monitor and no longer needs the stand. You can get a third party stand such as the one in the link below that will mount your monitor. All modern monitors have mounting holes in the back for VESA mounting, this is a standard configuration.
http://www.amazon.com/Adjustable-Tilting-Mount-Bracket-10~25inch/dp/B003L171KW/ref=sr_1_12?ie=UTF8&qid=1339684562&sr=8-12&keywords=monitor+stand
2answers
Taking stand off screen
The base can be removed by pressing the tab on the back of the stand. I do not think that the actual "neck" of the stand can be removed.
I found a manual here (has a few helpful diagrams): http://www.retrevo.com/support/Acer-X223W-Monitors-manual/id/23224ci553/t/2/
In moving to a new apartment I flattened the neck of the circular stand with the monitor LG flatiron slim 19" into the box. Went very easily. Now when I put up my computer the stand of the monitor...
On my HP monitor on the stand, I have a locking mechanism that doesn't allow the display to be raised. I need to press a button on the stand while pushing down the display, then the button is possible to be pressed down. then while holding it down, I can pull the display upwards as much as it comes.
the stand locks in my case when pushed all the way in.
Maybe this is the same thing on yours? Maybe not?
1helpful
How to remove stand from iiyama E2607WDS monitor
One can only remove the plastic neck of the stand by removing not only its four visible screws, but also the two screws at the invisible inside of the neck. To get to these, you have to remove the neck together with its metal foot. To do so, you should remove the 4 [four!!] bolts/screws that fix the metal bracket to the frame of the monitor, and then loosen the two screws at the outer left and right of the plastic back of the monitor [to get some room to move], and then slide the metal foot down and out. After removing the neck [and if you wish: also the metal] you should reposition all 4 four!] of its bolts/screws, since these are needed to keep the front and back of the monitor together. Also thighten the 2 screws at the outer left and right.
10helpful
3answers
How to remove Stand and Neck from LG M227WD 22
First remove the stand. Then remove the bottom of the tv carefully by removing the screws. Then put your fingers between the bottom and the tv, and pull carefully. now you can remove the neck.32e1e02.jpg4c05683.jpg2acdd66.jpg
Does the neck of the stand come off so i can put it on the wall
Yes here's a link to the manual
Make sure you have adobe reader to view it.
http://www.lge.com/products/mobile/cdma_manulist_gcsc.jsp
1helpful
Acer 2223W monitor stand
There are indeed generic stands which rotate between portrait and landscape orientation. This monitor, like most monitors sold today, has generic "VESA" mounting holes, in the 100mm x 100mm (MIS-D, 100, C) configuration shared with most other flat screen PC monitors, so they can easily be used with a variety of stands that attach to the 4 holes in the center of the back side of the monitor.
Monitor stand and power cable needed
Hi Kiran,
If the power cable matches the power cable of your computer, it's a standard 3 prong power cable and you don't need a specific kind. If it's a small circular type you will need an external AC adapter, the type will depend on the manufacturer and make of your monitor. These can be found on eBay usually. Most monitors use different types of stands, but if your monitor has the standard VESA 75 or 100mm mounting holes on the back, you can find many monitor stands that are compatible with it. The standard VESA mounting holes are usually used for wall mounts but lots of stands connect to the monitor this way. You can tell by a set of 4 holes for screws or bolts on the back that are either 75mm or 100mm apart (vertically and horizontally). Don't forget to get the right kind of bolts for the stand, if it doesn't include them.
Snapping sound
Could have a shorted gun, or a small crack in the neck of the crt
NEC MultiSync LCD1512 Monitor Logo
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Michael Thomas
Michael Thomas
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
