Question about Denon AVR-4800 Receiver
Cannot get sound from center SL and SR speakers...FL and FR speakers and sub work fine...
Posted by touchpad68 on
Anonymous
    New Friend:
    Problem Solver:
  • 6 Answers
Find the menu on the reciver. there will be adjustments for each speaker. if not that. change it to a different sound setting like cinama,rock,surround,movie,ext. try each one differ setting use differ speakers
Posted on Feb 11, 2011
How do I hook up the receiver to the subwoofer to the tv
Here's the Owner's manual -> https://docs.google.com/viewer?url=https%3A%2F%2Fwww.paradigm.com%2Fdownloads%2FOM-100.pdf.
There are many ways to connect the system depending on your receiver's outputs and the speakers. Usually, the TV L/R output connects to one of the receiver's inputs. The receiver's preamp sub output goes to the powered subwoofer. The receiver's FL/C/FR/SL/SR/RL/RR speaker outputs go to the respective speakers.
I hv a Denon AVR 3805, i tried to set it up but after doing all the necessary, i found out that it was only running on 3 speakers (FL,FR & SW). I did connect the center speaker but the sound just...
SW means sub woofer, not necessary means center speaker in all receivers. Instead of setting 5ch stereo, if you have 3 speakers. try to set "3channel" or "simulated". If you own more than 3 speakers, you may refer to the user´s manual to correctly wire them to get the full sound.
I need wiring diagram for the 5.1 output What is sr sl l/fl r/fr
I used one wire at a time, listened out of what speaker they were playing.
2helpful
How to hook up protron pds-2315
First of all, the PDS-2315 is not a DVR (this question is incorrectly categorized), it is a home theater system. Also, this system is not a receiver -- it is a DVD player (DVD/CD/HDCD/CD-R/CD-RW/Kodak PCD Playback) with a "full function" Karaoke feature with two microphone inputs. If you haven't figured out how to set it up in the past 11 months, this is how you do it.
1. Connect the supplied RCA cables (labled FR, FL, SR, SL, Cen, and SW) to the corresponding RCA connections in the back of the DVD player and the back of the Sub-Woofer.
2. Connect the DVD Player to your television.
A. Video:
There are several options here depending on your available Television inputs: Coax Cable, Component (yellow jack), S-Video and Composite (composite providing the best video resolution and coax the poorest). HDMI is not available. Use s-video or composite if you can. You will note that the composite RCA jacks are colored Orange, Blue, and Green. In a pinch, any RCA Cables will work - just don't cross the color codes between the DVD Player and the television. If you need to use coax you will need a coax to RCA adapter. If your television only has a component jack (yellow), it's a simple connection between the two.
B. Audio:
On the back of the DVD player you'll find two RCA jacks labled "Main R" and "Main L". These will be connected to your Audio Out connections on the back of your television. If you don't have Audio Out RCA jacks on the back of your television, but have an earphone jack, you can purchase an RCA adaptor to make that connection. With rear audio out jacks, you should have an option in your television's audio setup menu to select those outputs. (DO NOT CONFUSE "AUDIO OUT" WITH "AUDIO INPUT" because the will look identical.) If you don't have either of these connections, you will not be able to use the system to listen to television signals.
3. Connect the speakers. Each of the speakers is labled with their position (FR, FL, CEN, SR, SL). The speaker wires are color coded to the spring connectors in the rear of the sub-woofer/amplifier. Press the spring lever and place the wire into the opening. For proper biasing, place the color coded wire into the colored spring connector and the other wire into the black connector for the specified speaker. Connecting the speakers should be very easy. If the ends of the speaker wires become damaged, simply strip the wires back half an inch and connect as above. Place the speakers as specified by their position lables (FL, CEN, FR in front of the television and SL and SR to the right and left of the seating.)
4. Plug it in and power on. You'll need to plug in both the DVD player and the sub-woofer. Press the power button, hit the open/close button on either the DVD player or the remote control and put a disc in the machine. If you don't have a picture or a "Protron" title screen, hit the "P-SCAN" button on the remote (top left corner below the "STANDBY" button).
5. Hit the "SETUP" key and enter your system's information and you're done. Your system will work just like any other DVD player with theatre quality sound. --With the added feature of functioning as a Karaoke machine! Just add proper Karaoke CDs, a couple microphones, a bunch of friends and copius amounts of alcohol . . .
2answers
Subwoofer feedback, and no sound
Hi
Take it back and get another if you can.
2answers
7.1 Sound problems in Vista
check if your systems has sound card fully installed
2helpful
SB speakers error
I had the same problem but fixed it (no thanks to what I believe is an oversight by Pioneer!). The amp is a 7.1 system. What we are assuming is the rear surround (SB) is the default using a 5.1 setup. The amp uses the SR & SL as the default. So the solution is plug your rear speakers into the SR & SL & you should have your surround! (only took me 6 hours to figure this out, hope it saves you time!)
Out to speakers only in 5CH mode, or front L/R
set it on dolby digital mode not sterio mode should be differnt modes on a ch only use prologiic or spin the mode dial to doby digital on movie on direct tv wont be dobly fake suround more less but center should work change settings modes
JSI js5001 Home Theater
My dvd player won't go on. Worked one day the next day wouldn't work any help?
Denon AVR-4800 Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
tina gallow
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
