Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
My 12 year old Sony Trinitron KV-32XBR200 still works pretty well except that it cuts off about 25 - 30 scan lines at the bottom of the screen when cold, then gradually improves somewhat to missing only 15 - 20 lines when it warms up. Is there some sort of vertical size/shift adjustment to the CRT gun to correct for this?
Posted by amurray35 on
Chi Chu
  • Sony Master
  • 8,457 Answers
No,tv have cold solders inside the tv like vertical IC or around the area.Have a soldering iron,a roll of solders,also know how to do basic soldering?Yes.Take the tv aparts,take a back plastic of the screw driver tabs all around the main pcb,will see the vertical changes,take out the a/c power sourced,resolders those area,will fix this problems.
Posted on Feb 10, 2011
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
May 01, 2012 | Televison & Video
Sony trinitron 36" has 7 red blinks wont turn on
I HAVE A SONY TRINITRON KV-36HS510. IM HAVING A PROBLEM,ITS NOT SHOWING A PIC, AND BLINKING 7 TIMES THEN PAUSE FOR A COUPLE OF SECONDS THEN IT WILL BLINK 7 MORE TIMES,I CAN HEAR AUDIO BUT CANNOT SEE PIC. COULD YOU PLEASE HELP ME OUT ,I'VE TRIED CUTTING THE TV OFF FOR ABOUT 6 HOURS AND CUTTING IT BACK ON,SAME RESULTS, THANKS
Jan 02, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
I have a Sony trinitron XBR and I can't get the PIP turned off.
A solution I found for our KV-32XBR200 was to press Setup on top of the set, then select the "Demo" item with TV/Video. The text overlay apparently banished PIP. Verified this twice, as I'm at this page because our remote can only turn PIP on :-).
Aug 23, 2010 | Sony KP-53XBR200 53" Rear Projection...
Sony Trinitron XBR TV, picture-in-picture got
Dec 24, 2009 | Sony Televison & Video
Hello, I have a Sony FD Trinitron WEGA #KV-36FV310 manufactured around 03'-04', all of a sudden lately i've noticed a ghosting blue line spiraling up the screen,i only notice it when the screen gets dark,...
It's the return of the line, it should be cut off completely. To make it invisible again the cutoff point for the blue cannon should be adjusted (practically this means - turn a potentiometer) - all it takes is a screwdriver and the necessary knowledge. How much it will cost - that depends on how expensive your repairmen are
Dec 04, 2009 | Sony FD Trinitron WEGA KV-36FV310 36" TV
Comes on and later goes blank
How much later? The Sony sets have a setting in the menu that turnes the TV off if there isnt' any input, Sometimes this feature gets messed up, and the feature has to be turned off, Check that out and see if that takes care of the problem.
Oct 01, 2009 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Top of screen slants on the right and left side horizontally
go in touch with SONY i assume ur set is still under warrenty.....call customer help and support
Mar 12, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony trinitron TV KV-27TS27 screen remains dark
how do i adjust the brightness if i dont have the controler?
Jul 24, 2008 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Sony wega tv problem
no,most of cases is only cause of loose contact.
Oct 18, 2007 | Sony KV-32XBR200 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
