Question about HP MSM710 MOBILITY CONTROLLER (J9325AABA) Firewall
I am have passthrough issues with Procurve MSM710 Controller. I have to allow mac based authentication for let say Xbox live or PS3 to be able to go online. Is there a way I can define ports (port forwarding) or define rules for these application so they can get online without any issues? or without mac based authentication
Posted by perry653 on
murray343
    New Friend:
    Problem Solver:
  • 4 Answers
Hi Perry653,
If you do not want to use mac authentication - are you using an AP that supports VLANs? If so - then create an SSID tagged to a VLAN, with WPA security - and have these PS2 type of devices connect to that SSID - then create a VSC with that VLAN as ingress, and disable authentication.
If that is not an option, then your login web server can detect the UserAgent of the device, and do a NOC based login - this is subject to spoofing of UserAgent (but MAC is also subject to spoofing).
Finally, you could disable authentication, and use Tools/Trace to capture the packets that the Xbox uses, and whitelist in the ACL those ports, then re-enable authentication. I suspect the Xbox also uses port 80 (http) and if so, this method defeats the entire login page redirection.
So mac authentication really is the best method. We operate / manage / installed over 2000 of these type of devices, perhaps we can help you with your project.
Regards
Murray
http://wireless.deepcoolclear.com/
Posted on Feb 11, 2011
Users
The MSM720 allows 250 guest users. From what I know of networking this should apply to your product as well.
Mar 20, 2014 | HP MSM710 ACCESS CONTROLLER
How to hook up XBox live to your router
You need to allow your router proper MAC address assigned from your xBox live, and allowed in router firewall, those things can really make problem to you :) And enjoy playing! :) Seyaa around, please rate my solution :)
Apr 13, 2011 | Linksys Computers & Internet
We have a Procurve MSM760 Controller with 6 MSM310 Access Points setup in our office. We can't seem to ping individual hosts (PCs) over the network. Any solutions?
You should disable client isolation (in VSC, allow traffic between [ALL] wireless clients).
Are the MSM310 in controlled mode or autonomous?
Murray
http://prowifi.net
Mar 02, 2011 | HP HEWLETT HP PROCURVE MSM760 MOBILITY...
My xbox live is not working and my connection to the internet is on
Do you have an Xbox Live Gold Membership? To get Xbox Live you have to buy the membership, that's why a lot of people go with PS3 because you don't have to pay a monthly bill. But if you do have a gold membership. Press the Xbox button that has a big green X on your controller and then go to settings. Go to system settings, then go to network settings and select which connect your xbox is connect and then test your Xbox live connection. Hope this helps!
Mar 01, 2011 | Microsoft Xbox 360 Console
We have a controller hp MSM710 and we are using ProCurve Wireless Access Point 10ag also but when we connecting the wifi several times asking the user name and password let me know about this
This is likely a config problem. how often does the msm710 prompt you to log in again - after a few minutes or longer. We can review your config remotely if you like, we also host a Radius backend.. http://prowifi.net
Murray
Feb 23, 2011 | HP MSM710 MOBILITY CONTROLLER (J9325AABA)...
We can't find the firmware updates for the MSM 760 J9421A (from Software version 5.3.1.0-01-7143 to release 5.3.5) to solve the issue of authentication experiencing serious timeout issues, as well as...
http://h17007.www1.hp.com/us/en/support/converter/index.aspx
at the top line, type J9421A. It will find your device. Select Software downloads.
If you continue having troubles, contact HP ProCurve Support at 1-866-my-procurve. They should be able to help out.
Dec 03, 2010 | HP HEWLETT HP PROCURVE MSM760 MOBILITY...
3 vlans, data,1; data 2,;voip,5. Ports carry voice tagged, and data. currently Windows 2000 DHCP server lives on Vlan 1 (AND WORKS). Need to upgrade. When we test the new servers we are unable to make both...
Here's what you need to do:
First, be sure to assign an ip address(in the proper subnet) to each VLAN.
Second, use the ip helper-address command in the context of each VLAN, the address used should be the address of the DHCP server
Third, Add a scope for each additional VLAN on the DHCP server.
The switch will route the DHCP request to the proper server based on the ip helper-address command parameter and based on the ip address of the VLAN that is passed tot he server, a DHCP address in the proper subnet is automatically configured.
Here is a sample:
ProCurve Switch 3500yl-24G-PWR# configure
ProCurve Switch 3500yl-24G-PWR(config)# vlan 33
ProCurve Switch 3500yl-24G-PWR (vlan-33)#ip address 192.168.33.254/24
ProCurve Switch 3500yl-24G-PWR (vlan-33)# ip helper-address 10.1.2.250
Aug 06, 2009 | HP ProCurve 4104gl Networking Switch
Ps3 goes online to web, but can't connect to other players online
open these ports in your router and see if that helps.
TCP: 80 443 5223 10070 10080 UDP: 3478 3479 3658 10070 Please follow the steps below to setup your Xbox with your Linksys Router:
  1. With your Xbox powered down, take an Ethernet cable and plug it into a numbered port on the router, and plug the other end into the Xbox.
  2. After you have your Xbox connected to the router, start up the Xbox without a CD in the tray.
  3. After you start the unit, you should arrive at the “Xbox Dashboard”. Select the Xbox Live option and press the “a” button on the controller.
  4. After “Xbox Live” loads select the Network Setup and press the “a” button your controller.
  5. On the “IP Address” settings, you can choose “Automatic” or “Manual”, make sure it’s Automatic.
  6. Select the Connect option and press the “a” button on the controller.
After you use the “Connect” option, the Xbox will detect the network cable, and will ask you if you want to connect to Xbox Live
Armymason
Mar 02, 2009 | Linksys Wireless-G WRT54G Router
Must i get a xbox 360 or Ps3?
Both consoles have advantages.
The Xbox 360 has a vast array of titles and has the biggest fan base of the two. If you connect the console to the internet, you can download games and movies through Xbox Live. You can also connect your PC to your Xbox 360 and use the console as a multimedia center using Windows Media Center.
The PS3 has a blu ray drive as standard, so you can watch blu ray movies through your PS3. DVD's are also upscaled up to 720p to improve the look of your movies. The PS3's online service is free, and allows you to download game demo's and downloadable content for games.
The Xbox 360's disadvantages are the fact you need to pay for access to Xbox Live, roughly £40 per year, but it does guarentee a reliable online service. Also earlier and cheaper models of the Xbox do not support full HD via HDMI.
The PS3 is very expensive and lacks quality titles. The console is also on a 10 year plan, so even though the console will outlast its rivals, it is likely to become outdated.
If you want to watch blu ray films and play games occasionally, go for the PS3. If you want a console with a lot of titles and a reliable online service,  get the 360. Of the two I'd choose the 360, but in 2 years or so I might need to reconsider.
Feb 18, 2009 | Microsoft Xbox 360 Console
HP MSM710 MOBILITY CONTROLLER (J9325AABA) Firewall Logo
713 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
