Question about GE Freezer  14.8 Cu. Ft. Manual Defrost Chest Freezer
I need a Freezer Operation Manual. GE Model FH15D
Posted by bonavela on
No power to the compressor
The thermostat circuit is responsible for sending power to the compressor for normal operation. Make sure that the thermostat is working and not stuck on open position.
Aug 15, 2014 | GE G.E. Profile Bottom Freezer 25.5 Cubic...
Freezer runs for approx. four days with operation normal. Then the temp. panel of front door displays a symbol that looks like a short L followed by a period. Then the temp. gauge and the interior light...
From what I read, the "L." that you see on the control panel indicated that the controls have been locked. According to the manual if you hold down the "alarm reset" button for 3 seconds the "L." will disappear allowing you to control the temperature again. I don't as of yet know what is causing your overall problem though...
Nov 04, 2013 | GE FUF14SVRWW Upright Freezer
What type of light bulb does the freezer use
May I get the model # so I can help you get the right bulb
Aug 22, 2010 | GE Freezer  14.8 Cu. Ft. Manual...
User manual for GE upright 5 cu. ft. freezer
May I get the model # of the freezer so I can help you more
Aug 19, 2010 | GE Freezers
Light not working in GE chest frezer it is larger than the model below, 22 cf, it is 25 years old.
Check the bulb, check the tabs within the socket, check the door light switch.
Please, unplug fridge when testing these. We'd like to hear from you again.
Mar 27, 2010 | GE Freezer  14.8 Cu. Ft. Manual...
I was just given a ge chest freezer model # cb10 dk serial number vv186793. i cleaned it up and plugged it in about 5 minutes later it started buzzing . i turned the control to the lowest setting (0). and...
switch on and leave it to freeze.approx 24hours.buzzing could be compressor working overtime to get cold.or in fact the freezer is not on a level surface.
Mar 02, 2010 | GE Freezer  14.8 Cu. Ft. Manual...
Need wiring diagram for GE model CA15DRN upright freezer-compressor relay busted & not sure which wires go to which terminal on compressor.
http://genet.geappliances.com/DocSearch/pdf/49-6545.PDF
The best I could come up with is this site for the user manual. Not able to find wiring diagram on this GE site. Hope this helps ya.
Nov 24, 2009 | Freezers
GE Freezer  14.8 Cu. Ft. Manual Defrost Chest Freezer Logo
104 people viewed this question
Top GE Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a GE Freezer Expert? Answer questions, earn points and help others
