Question about Fuji FinePix F410 Digital Camera
Switch on appears OK. Take pic and it appears briefly then fades, attempt to switch off and kens will not retract. Putting mem stick in computer indicates that the pic was stored. Can only retract lens by placing the power on cradle.
Posted by don_parry on
Andrea Lock
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 10, 2011
In saved data utility, appears there is no memory stick inserted but it has. i cannot play my games because of the problem.
Hi.
Looks like a broken memory stick!
  • Try another memory stick, if it works or open your memory stick in any computer just to check if it is still working.
  • Open the mem stick in your PSP to check also if it is being read, if not, clean the gold contact points, and try it again in your PSP.
  • If the mem stick can be read by your PSP, that means the program is already corrupted and you have to format it.
  • If it still not working the problem is the mem stick is now broken
Hope that helps you out!
Aug 12, 2011 | Sony PlayStation Portable (PSP) Console
My son loaded some pictures from his camera onto my laptop, but the laptop will not let me view them. I bought a memory stick thinking that I could load the pictures onto it, and then transfer them to my...
maybe the pictures are corrupt files, if so what will transferring them to your desktop accomplish. If the files are good and you have the appropriate software to view them you should be able to on the laptop.
However if you want to try...
1) put in mem stick , when laptop recognizes it go into my computer
2) click on the icon for mem stick and minimize it
3) open my computer a 2nd time and click on drive pics are on
4) click on the first file / first pic and the while holding down shift key go to end of list of files that are the pics
5) rt click and press cut
6) then go into the other my computer open which should be the mem stick then rt click and hit paste
7) remove mem stick from laptop and place it in desktop
8) when desktop recognizes it , gather up all pic files with the shift key procedure done on laptop
rt click cut/copy
9) then go into c drive or applicable hard drive then rt click paste
Mar 30, 2011 | Computers & Internet
Update failure; system status code. 3151-0000-D080-0200-8007-045D. What I've done: Cleared HD cache... no joy. Removed wireless and switched to cat5... no joy. Connected directly to Modem...
I can't really find anyone who has been able to fix this issue. Have you hooked it directly to the modem via the cat5 cable? I wasn't sure if you meant you hooked it to the modem or router.
Mar 08, 2011 | Computers & Internet
FinePix F470 Lines on images and faded colors on photo mode.
You have over exposed pictures due to the shutter sticking.
The video is the clue to the problem. It doesn't use the shutter.
Shutter needs to be cleaned. This is no easy task im afraid
Sep 11, 2009 | Fuji FinePix F470 Digital Camera
How do i remove write-protection from MemoryStickPRODuo from psp?
1. Remove memory stick from psp
2. Plug in usb cable and start usb connection
3. Insert memory stick and now you should be good
For some reason you might have to repeat these 3 steps everytime you want to access your memory stick
Hope this Helps
Apr 18, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
SONY DSC-H3 File Error after taking pictures
ok try this pls take out the mem stick b4 going fwd
factory reset the camera
Home Screen>Settings>Main Settings1>Initialize press OK on Control Button and then OK select Initialize All Settings press OK
then pls turn off the camera and take out the battery then move power switch of camera to ON position for 1 minute
after 1 minute move power switch to OFF position and then put the battery back and see everrything is OK
if it doesnt help then my friend ur CCD imaging Device is Faulty
pls let me know with the results
Rate me FIXYA if i fixed ur problem
Jan 27, 2009 | Sony Cybershot DSC-H3 Digital Camera
Need instructions on puttin photo onto PSP
first, you need to plug the psp into a computer.using the computer, go to the mem stick and find the file MUSIC. if there isnt one, then create one. place your music in that folder.
for pics, go to the mem sick and find/create the file PICTURE.
place pics there
note:make sure the MUSIC and PICTURE folders are in caps
Jan 26, 2009 | Sony PlayStation Portable (PSP) Slim...
Format error c:13:01
i don't think you can transfer photos from mem stick to internal mem, but may i suggest purchasing a multi port card reader? it is a small device, compatible with most all mem cards- deff for Sony Cyber-shot- you simply insert your mem stick and plug into the USB port on your computer, this will also save unnecessary wear on your camera, They are fairly cheap, at around $15, no software is needed, your computer will recognize it as a mem stick, just as it does the camera
Nov 01, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Fuji FinePix F410 Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Rob Hill
Rob Hill
Are you a Fuji Camera Expert? Answer questions, earn points and help others
