Hello julian_ad681
I will tell you how wire your case front panel, but before that lets test the motherboard to make sure the problem is not the board itself.
Remove all the wire connections to the front panel.
Turn the power on and with a small screw driver or anything that is metal short (touch) the two pins that are the PWR SW. (look at the list of pins I have put at the end)
If the computer turns on then it means the board is ok.
The following information is also availabe in the motherboard manual available from the gogabyte web site download section
On the motherboard next to the battery is the front panel header pins. it looks like
0 0 0 0 0 0 0 0 i also write them as numbers as well to make it easy for you)
0 0 0 0 0
1 2 3 4 0 0 0 0
5 6 7 8
1 and 2 are message LED. you don't need any connection to this.
3 and 4 are the power switch connections no polarity, just connect the wires
5 and 6 are the hard disk LED. 5 is the positive side (usually red)
7 and 8 are the reset switch. no polarity, just connect the wires.
Next to the message LED there is a three pin connection. This is for the power LED.
hope this has helped you.
please leave comment, vote if the helped
Drivers?
Always
get your drivers and specific software from the manufacturer of your
Laptop, Notebook or Desktop. They are usually free of charge.
If you were to log on to the
manufacturer's
web
site,
usually one is able to download if available, by model
number,
All
available Driver
downloads
as required.
If the driver is not
available, perhaps your manufacturer does not support the OS you are
installing.
This is the best way of ensuring up to
date drivers for your system and they are free of charge!
I hope this helps.
