Question about Panasonic Lands Phones
The telephone batteries are fully charged; however when I attempt to use the telephone I receive a message stating, "No link to base. Move closer to base, try again." The telephone is very close to the base
  • Panasonic Master
  • 2,460 Answers
Check your user's manual for registration, or RE-REGISTER the handset to the base. In essence, it involves stepping to the registration on the handset, pushing the handset locator button on the base, then saying OK on the handset. They will sync up.
Carl
Posted on Feb 10, 2011
Phone out of range
The phone has a predetermined limit on how far your phone can be away from its base. You have to either move the base closer to the phone or move the phone closer to its base. Weak batteries can cause this problem too. Batteries cannot be recharged forever. Replace the batteries with new ones.
Oct 24, 2015 | Uniden DECT 6.0 Cordless Telephone...
My phone is always on it's base until I lift it to use it. Since a few days ago, when I pick it up, press "talk", I see the message "no link to base. Move closer to base." Why is that...
Maybe the battery isn't holding charge. One of my home handsets can only be off the base for 30 minutes before it totally dies. I've heard that staying on the charger too long kills the battery.
Apr 03, 2011 | Cell Phones
Both phones in the set display the message "No link to base. Move closer to base, try again." I have reviewed and implemented the troubleshooting instructions to no avail. All suggestions are...
We have a Panasonic that is starting to go stupid. After 4 or 5 years, with a fully charged battery we register it but it only stays registered for about a day or two. If yours is acting the same way, well cordless phones aren't that expensive anymore.
Mine is the cute red one.
Carl
Feb 06, 2011 | Panasonic KXTG2344 Cordless Phone
My cordless phone says No link to base Move closer to base - I have no dial tone - do i need a new battery?
This is the usual message that the phone gives when the battery has died and it has lost connection with the base unit. The usual fix is to remove and reinstall the battery, then place the unit on the charger for a full charge. This will usually fix the problem that you discribed. If after a full charge, you still get that message, you will most likely need a new battery. Good luck...
Nov 06, 2009 | Panasonic Lands Phones
Handset is fully charged and states No Link to base. Move closer to base, try again. This does not work as it has been tried.
before using the phone,the handset has to be registered with the base...from the menu select handset registration..then press the speaker button for some time which will register the handset...if u have a manual for this phone,please try from that book about handset registration..
Oct 22, 2009 | Panasonic KX-TGA101S Cordless Handset
I have a remote phone it does not have a telephone wire just an adapter. It is charged but I can not get a dial tone. It gives me the message "No link to base. Move closer to base,try again". What do I...
Place the phone in the base cradle for a minute and it should re initialize and solve your issue.
Good luck.
PS: By "Remote phone" I am assuming that you mean "Cordless"?
Apr 11, 2008 | Lands Phones
Link to Base
unplug both wires at back of base and replug after about 5 minutes - it should work now
Dec 30, 2007 | Panasonic KX-TG2357 Cordless Phone
Telephone problem
you monkeys did not help me i hope you get hit by a bus its called carma
Dec 16, 2007 | Panasonic 5.8GHz Cordless Telephone
Lands Phones Logo
450 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
