SOURCE: Sharp AR M455N copier scanner will not scan to Windows 2000
Check the webpage under destinations and make sure the IP address is correct for this pc. can get to webpage by opening Network Scanner tool, hitting the scanner tab, then web setup button.
Also make sure the Network scanner service is running in the system tray (by the clock) and that it says the service is started by hovering over it with pointer.
SOURCE: Network Error code CE-02
the ce-02 code is just a communication error it general in nature so you could have a couple different issues going on
SOURCE: Sharp MX-M350N Error CE-03
CE-03 is a communication error, obviously. Your print card and your new SMTP are not talking together. Your system is probably OK at this point, but is unable to communicate well with the new network system. Work with an IT department to resolve this.
SOURCE: HOW TO RESET SHARP COPIER AR-M350N AFTER FUSER WAS
must enter into simulation mode. press"P""*"Clear""*" then press"14 " then press "start" then press"0" then "start" again. if 14 doesn't work substitute 15,16 or 17.
