Question about Honeywell Heating & Cooling
Sounds as if the overload switch is turning it off, either because the burner chamber is overheating or the overload switch needs to be replaced. When you turn it off and then back on, the switch resets itself.
Posted on Feb 10, 2011
Mar 02, 2017 | Coleman Heating & Cooling
Feb 04, 2014 | Heating & Cooling
Dec 14, 2013 | Honeywell Programmable Thermostat Heater
May 12, 2017 | Heating & Cooling
Mar 02, 2011 | Honeywell Programmable Thermostat Heater
From the description you give the most likely cause of this problem are bad gas coils or a bad gas valve.
You say you see the flames for 10 minutes before it stops heating but you don't mention if the igniter is continuing to glow. One thing we need to know is if the igniter continues to cycle on and off when the dryer stops heating.
There is a small square plug on the front panel you can remove to try and visually check if the igniter is glowing.
The problem won't be the thermal fuse or one of the thermostats. Once the fuse is open the dryer won't heat but it won't start to heat after 20 minutes.
After the dryer runs ten minutes and stops heating then check if the igniter is still cycling on and off. This is important because if the igniter is working then the thermostats and igniter are okay.
When the igniter glows at some point you might hear a click and the igniter would stop glowing. The click is from the flame sensor and after the click and the voltage is removed from the igniter at the same instant the voltage is applied to the gas coils and you should get a flame.
You might hear a hum, buzz or vibration from the coils when this happens. If the coils seem to react to the voltage but there is no flame then most likely the gas valve is bad. If the coils don't do anything then most likely the coils are the problem. The gas valve and gas coils can work for 10-15 minutes and then heat up and stop working till everything cools down.
One other thing I must tell you about the gas coils. Here is a link to the gas coils you will need. These are the new style that will last quite a bit longer the the older one. The coils are like the spark plugs in your car. The will need replacing in time due to wear. Below is a video to walk you thru the repair process.
You-Tube video "RjonjNitfVk" placeholder
Jan 09, 2011 | Frigidaire GLGR642A Gas Dryer
Jan 27, 2010 | Heating & Cooling
Jan 10, 2010 | Heating & Cooling
Jan 06, 2010 | Goodman GMS90703BXA Heater
Jan 17, 2009 | Weather King 10AJA3601AH Air Conditioner
