Question about Mackie 1202vlz3 12 Channel Mixer
What exactly do I need to connect a Mackie 402-VLZ3 to a Macbook Pro ? Where can I buy the cables? Thanks!
Fred Yearian
  • Mackie Master
  • 5,603 Answers
The internal audio systems in the PC's are inadequate for high quality work. You should get an external audio system that attaches via firewire or USB to your MAC. Then use balanced cables from the mixer to this audio interface. There are MANY different audio interfaces... Search the music equipment suppliers in the "recording" section of their catalog...
Posted on Feb 10, 2011
  • Anonymous Feb 10, 2011
    Appreciate the fast response, but needed your recommendations for specific products. I know there are MANY different audio interfaces. I probably didn't make the request clear enough.
  • Fred Yearian Feb 11, 2011
    There are so many devices and different prices... First choice is if you want to use USB or Firewire... If you can use USB I would go that way as you can probably use it with a friends PC as many PC's don't have firewire.
    Exampls are Avid Pro Tools Mbox about $550 (higher end)
    PreSonus FireStudio Mobile 10x6 About $300 advantage more inputs
    Cakewalk UA-25EX USB Audio Interface about $250 lower end but they work two inputs only
    M-Audio Fast Track Pro Mobile USB Audio/MIDI About $200
    PreSonus AudioBox USB 2X2 USB Recording System about $150
    Lexicon Alpha USB Desktop Recording Studio about $60
    Myself I have been using the Cakewalk units that I only paid $50 for as non-working parts only units from salvage and I repaired them and they work perfect.
    Personus is used by many pros and as I said there are many prices and MOST do a pretty good job of recording. Since you have a mixer, you REALLY only need two channels... HOWEVER evaluate if you might want to multitrack in the future before going to only a two channel unit.
How can i get more volume on my onstage monitors thru my mackie 2404 vlz3 mixer or what is the proper way to connect the monitors
Without more information of your speakers and amps we can't really help you. The Mackie board puts out line-level signals and that should drive any connected amp or powered speaker to the full capability. Make sure you are using BALANCED interconnect lines either XLR or TRS cables. Use of TS unbalanced cables costs you 6 DB and also noise pickup. Make sure ALL your gear, amps, speakers etc are powered from a SINGLE receptacle or power conditioning module. Normally you will use the AUX outputs of the mixer by way of TRS cables or balanced lines in a snake to power amplifiers onstage which then connect to the stage monitors. If you have powered monitors the returns of the aux to the stage go to the powered monitors. A heavy duty extension cord brings power back from thee stage power to the mixer.
Sep 06, 2011 | Mackie 2404-VLZ3 Mixer
Hello, I have a Mackie 1604 VLZ Pro from 1995. It's 110 volts and I want to change it to 220 volts. Do I need to buy a new transformer? I don't want to us an external step-down...
The LEAST expensive thing to do is to buy an external stepdown transformer.
Here is a link:
http://www.world-import.com/transformers.htm
The 100 Watt would be adequate... If you think you might need more you could have a reserve for other equipment... At around $8 USD I don't think you can beat that. The labor cost to change the internal transformer would cost many times what the external transformer costs, not to mention the cost on a new internal transformer.
Jul 24, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
I cant get my mackie 2404 VLZ3 to record any audio? I have the board setup to record from the master but no audio comes into my computer. What to do next?
check your cables, on some Mackie boards press the switch to enable master out, make sure the mute or cancle button is not pressed. i have a 2404 vlzpro mixer it's simular to yours, if you have any problems, you can call Mackie direct if the issue is not solved, it could be a bad button, fuse or slide controle, or even a fuse
Dec 12, 2010 | Mackie 2404-VLZ3 Mixer
Some of my channels have stopped working 4-5-6-13-14-15-16 mackie 1604 vlz pro
If you havent ground looped the chanels. Most of the time the chanels need to be cleaned.
Dec 01, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Can i get a decent sound running an rca to usb cord from my mackie 402-VLZ3 to my macbook?
RCA jacks do NOT connect to the USB. One is aanalog audio, the other digital.
Sep 03, 2010 | Mackie 1202vlz3 12 Channel Mixer
Hello, Effects and EQ hook up problem
Many of those connections REQUIRE using TRS cables (stereo style) rather than TS cables (mono style). It is possible you have mixed the cables if it worked before.
Any cable plugged into an "insert" should be a TRS (tip-ring-sleeve) cable.
Look up these connections in your 1604 manual.
Feb 18, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Ch. 10 does not work - Mackie 1604-VLZ PRO
Yes, the ribbon cable is the 1st thing I would check. You can check the ribbon like this: Disconnect said cable from the channels. Connect cable connector from a known good channel to the problem channel. If channel sounds the same trace a signal through the channel op-amps.
May 26, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Hooking up powerd monitors to a Mackie 1604 VLZ3
Are you sending the main mix to the monitors or are you giving them their own mix? What about using the sub groups, use 1 for your monitor send.
Apr 04, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Mackie 1202vlz3 12 Channel Mixer Logo
716 people viewed this question
Top Mackie Music Experts
 Grubhead
Grubhead
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Mackie Music Expert? Answer questions, earn points and help others
