Vacuums Logo
Posted on Feb 10, 2011
I am in need odf a switch for a Master Flame es20 electric fierplace. It is a double switch. I can not find the owners manual.
Kim Mathews
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 21, 2013
Kim Mathews
Contributor
Level 1:
Answers
Questions
0
Helped
294
Points
0
Need one too cannot find it ... did anyone find one?
How to download an owners manual or sanitaire red mighty mite model 3683?
There really isn't much to know about this vacuum in the owner's manual. It has attachments, doubles as a blower by attaching hose to back end. Practice the usual safety standards like don't use near water. Ck the prefilter on bag changes. That's about it.
Why does my hoover belt keep snapping?
Hello! Your belt will need to be replaced about twice a year. If your belt is breaking within a couple uses of you changing it, you may not have the correct belt for your vacuum. Double check the owner's manual or Hoover.com to verify the belt number for your vacuum. Always replace the belt with a genuine Hoover belt. Hope this helped!
Owner's manual
sparked and smoked and you are not a qualified repair person and the owners manual will make no reference to how to fix
you have 2 options
repair shop
or
junk it
I am installing a ge #15070 basic timer and there are 3 wires. Which wire do I attach to the ground?
GE 15070 timer does not have ground wire.
I assume this timer is double insulated, just like some power tools and electronics only have two prong plug.
Leave bare ground wire attached to other bare grounds in the box, and shove grounds to back of box.
I have one of these timers installed.
Timer has red, black and white wires
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
How to wire GE 15070 timer:
1) Switch has 2 insulated wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
3) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
4) Turn on electricity, and slide switch to ON-or-OFF. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
5) Add a comment for more free help.
6) Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 13, 2011 • GE Vacuums
Shuts off after prolonged use.
what is the make and model. Some machined have a sensor that shuts trhem off when they get warm because this usually means the bag is full. also make sure all the filters are clean, If they are sponge you can rinse them. dont reinse any other type odf filters and also allow thye sponges to dry before turning iy back on.
Oct 07, 2010 • Vacuums
2answers
I have an Electrolux Oxygen 3 Ultra Canister Model No Rel7020. I am having problems with the On/Off Button and the Bare floor/Carpet Brushroll On/off button. The Carpet On/Off will not work at all. In...
You have a problem with the electrical switches. If you are comfortable with this, take apart and double check internal wiring to make sure nothing was frayed, or disconnected. Make sure it is unplugged. If you know how to operate a multimeter, you can use it to check continuity in each switch.
Red Light lit and it refers me to owner's manual.
Your problem could be many things, causing it to over heat, you need service by and Certified Tech. You can call the home office at 800-344-1840 to find an Authorized Service Center near you. Do not take it to a vac shop or you could end up with more problems than before.
FQ Master
888-637-4692 in Iowa
Your Authorized Filter Queen Service & Supplies
Electrolux 2100 foot switch
The owners manual is HERE: http://www.aerusonline.com/service/manuals.cfm
But it does not show the inside of the foot/power switch
Mar 03, 2009 • Vacuums
Electric motor does not work
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618630&thid=784776
Posted by prajuabmcb on July 14, 2008
Electric motor does work when switch is turned on. Tried different electrical outlets but still not work.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Dirt Devil 12 Amp HEPA filer vacuum cleaner. It sounds to me like you may have a 2 motor system according to the picture and it also sounds like it could be the bottom motor of which if it is not working well then it may need replacement – there is really nothing you can do for the brushroll motor other than replacing it. Question? Do you have any suction from the main motor? If you do then it definitely is the brushroll motor that needs replacement. You can always check your Royal owners manual under the trouble shooting guide or you can contact the Royal cust serv dept listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Hard Floor vacuum, solution doesn't dispense
You might check your owner manual to make sure that you switched it over for wet. If still no luck, and you said it was new, you have a years warranty, take it to a warranty repair shop.
Mar 26, 2008 • Vacuums
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
