Question about Frigidaire FEF366 Electric Kitchen Range
My oven will not stay at desired temp. It gets much hotter than the desired cooking temp. could this be a thermostat problem?
Posted by fickess on
Anonymous
    Champion:
  • 235 Answers
The thermostat is designed to regulate the desired temperature. If it is getting far too hot then the thermostat requires replacement.
Posted on Feb 11, 2011
Temperature when using frigidare oven, keeps getting hotter and does not cool down
Good Afternoon Andrea,
I see that you're having issues with your Frigidaire oven, and the heating element being red hot the entire time you were cooking no matter how much you turned the temperature down.
I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your oven, you will need to set the clock by entering in the time and pressing start. Preheat the oven, to whatever desired temperature, and if it is still running hotter than it should be, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Apr 22, 2014 | Frigidaire Ovens
I am a florist with a 26 feet src refrigeration box (unit), I cannot control the temp at the desired rate, it keeps fluctuating to a higher (hotter) temp. Need your advise
your going to adjust the thermostat setting if your thermostat is digital type you press it yuor desired temp. ex from 10 to 1 to adjust it to cool if your thermostat is analog to adjust it to cool rotate the knob clockwise to adjust the setting to cool but observe it to get you desired temp.
Mar 02, 2011 | SRC Refrigeration LD126-4 10'6' LongDoor...
I have an SL100 - 10W La Germania table top oven (gas) I did not receive a operations manual with purchase of the oven and I do not understand its operation. Questions 1. How does it maintain the set...
I GOT THE SAME QUESTION .. IT IS A GAS OVEN . WHEN THERMOSTAT IS SET TO GAS MARK 4 WHICH IS EQUIVALENT TO 350 DEGREES , AFTER 10 MINUTES, IT REACHES ITS DESIRED TEMP. BUT IF I DON'T ADJUST THE FLAME, THE TEMP WILL RISE HIGHER AND HOTTER THAT I NEED TO OPEN THE OVEN DOOR TO DECREASE THE TEMPERATURE INSIDE. ANYONE KNOWS IF THAT IS NORMAL? THANKS12_1_2012_3_54_19_am.jpg
Oct 26, 2010 | Ovens
The problem is that the oven seems to get hotter and hotter as if the thermostat doesn't cut out, i.e. i was cooking braising steak yesterday temp set between 150 -100 this just boiled over. so i had to...
You are quite correct in saying that the thermostat is faulty.
Only solution is to replace it with a new one.
This should solve your problem.
Nov 29, 2009 | Belling Ovens
Oven temp
after youve cooked at desired temp(400) for allotted time. turn off oven, and restart at 350. it wont start up right away( its already at 400, but it wool drop in temp and cook at 350. good cookin to ya!!!
Mar 23, 2008 | Amana ARGS7650SS Gas Kitchen Range
Creda oven
you might have already thought of this, buy an oven thermometer you can pop in the oven.
I bought one from my local cook shop
I have a the same cooker and similar problem - mine gets hotter by 50 degrees so I set the temperature 50 degrees lower than needed.
I noticed the problem a few years a go and luckily hasn't got any worse.
maria
Jan 02, 2008 | Ovens
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Oven Temp
After it drops temperature, how do you get it back to the desired degrees? It sounds like the thermostat isn't keeping up.
Nov 15, 2007 | Whirlpool RBS245PDS Electric Single Oven
Frigidaire FEF366 Electric Kitchen Range Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Michael Thomas
Michael Thomas
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
