SOURCE: Print light blinking
turn it off..let it set for 4 min..and then turn it on..try a test page first, though
SOURCE: No Paper Light wont go out
I had similar problem, but not exactly what you describe. The "no paper" light would come on when I would try to print labels in MS Word using paper tray #1.
I found and installed driver and firmware updates. Still the same problem. I could print the labels if I treated it like a normal document, but if I went into "envelopes and labels" it would always say "no paper."
I found that if I used the MP tray (the one behind the front cover) it never gave me the "no paper" error. I should have been able to use paper tray 1, but it wanted the mp tray for some reason.
SOURCE: paper light blinking, paper tray full, won't print
hi,
i recently bought a second hand hl-5140 and when switched on had the fault you have described - on checking machine over i found a small piece of torn paper stuck in the paperpath. after clearing, the printer worked fine.check over for paper again as mine was only a very small peice.
hope this has been of help.
pete
SOURCE: black lines down side of paper on HL-5370 brother laser printer
you have a bad drum... it needs to be replaced
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
