Question about Skull Candy Skullcrushers Headset
My jack is bended... :( the 3.5 mm one. the one that already connected with the headphone. how do i fix it? do i need to go to a music shop? or i can fix it myself?
Posted by sk8_soulja6 on
arron somerville
    Novelist:
  • 347 Answers
If you cant bend it back to place with plyers it will definately bend with heat from a blowtorch
if you cant fix it yourself then your screwed there are no shops that do such a thing
Posted on Feb 10, 2011
Tip
LG ENV as a touch connecting to an additional input
<p>You can use the 3.5 mm headphone jack on the Touch LG ENV to an audio device via an auxiliary input. If the audio cable is connected, the phone automatically updates all sounds cable. Then you can play music from the music player devices, such as car radios and systems external speaker. The 3.5 mm audio jack is a stereo connection, and is the audio standard for many electronic devices. <br /> <p><br /> <p>1. Connect one end of the audio cable to the 3.5 mm headphone jack on the Touch LG ENV. <br /> <p><br /> <p>2. Connect the other end of the cable into the auxiliary input device you are connecting. <br /> <p><br /> <p>3. Change the input of your audio device to take extra. Car radio, press the AUX button. See the device manual for specific instructions. <br />
on Aug 05, 2011 | Cell Phones
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
Can i hook up my PC to my sterio system through the headphone jack on the stereo to the PC HEadphone jack? been trying to get it to work on Auxilary but no sound :( please help
If you are still working on the question you asked about. This is what I would do. One of two things:
First: purchase an adapter that goes from your laptop 3.5 mm headphone jack to the microphone input if there is one.
Second: Would be to purchase what is called a "Cassette Tape Adapter". This will take your 3.5 mm headphone jack and play it through your cassette tape area of your stereo.
I hope one of these is a solution that will help you. -- wicc --
Aug 16, 2012 | Computers & Internet
Do I need to buy a seperate headphone jack adapter in order to put my headphones in? The headphone jack seems too small. If so what should I buy?
What type of headphone connector do you have? The Yamaha keyboard headphone jack is a 3.5 mm stereo jack (like on a computer headphone jack). So if the headphones have a 1/4" plug, you need a 1/4" to 3.5 mm adapter.
I hope this helps.
Dec 26, 2010 | Yamaha YPT220 PAK 61 Key Keyboard wAC...
Well i put music in the mp3 and the music sounds weird. the music dont sound like the music at all. like the sound was changed help!!
This device has fragile connectors in the headphone jack. Most of my headphones don't cause any trouble, but one of them always bends the contacts back so other headphones don't work properly.
Symptoms of this problem are: the sound becomes quiet; some frequencies are muffled or inaudible (especially vocals and mid-range); no stereo effect. To be certain that this problem is with the device and not the headphones, try it with a different set of headphones. If the problem remains, the device is damaged.
Unfortunately, the only solution is to open it up and bend the contacts back into the headphone jack so they can connect to the plug properly. This is an advanced maneuver, and you are very likely to break the device permanently if you attempt it. I've been doing this kind of thing for years, and this device was one of the most difficult to work with. Fixing it will be fun for bonafide hardware hackers, but everyone else will be better off just getting a new one. Give the old device to a kid who likes messing with electronics... they can probably re-purpose the battery and the case. :)
Sep 15, 2010 | Sylvania SMP2012SL 2GB MP3 Player
How do I fix a bad connection with the headphone jack on my ipod touch? When plugged in, the music is static-y. It is definitely the headphone jack that is the problem.
Hi, this seems to happen on a lot of mp3 players , usually when you wiggle the headphone in the jack the sound cuts in and out, its the result of the headphone jack bending the metal contact inside the player or can be due to a build up of dirt/ grime in the socket.The problem generally gets worse as time goes on
if you have tried it with different headphones still get the problem and its still under warranty I would get on the apple site or down to you local apple centre and try and get a replacement.
Sometimes a spray of deoxit (plastic conductive lubricant /cleaner)
in the socket does the trick , but I would strongly reccomend trying to get a replacemnt
Jul 23, 2009 | Apple iPod touch
Low and bad quality sound by headphone port
sounds like an internal problem
like a bad connection
if you have the skill, you could pull it apart and resolder the parts around the earphone output jack
hope this helps!
Jun 27, 2009 | iRiver X20 MP3 Player
Mitac Mio 168 sound - adapter 2.5 to 3.5 mm jack
I believe there is something wrong, its a normal stereo socket.
I use differend 3.5 to 2.5 adapter (standard, from the shelf)without any problem to connect an FM Stereo-Transmitter.
The best solution to connect your car radio, its wireless.
regards JK
Dec 09, 2007 | Mitac Mio 168 Pocket PC
Skull Candy Skullcrushers Headset Logo
Top Skull Candy Radio Communications Experts
 Grubhead
Grubhead
efs_perpends
efs_perpends
NOEL
NOEL
Are you a Skull Candy Radio Communication Expert? Answer questions, earn points and help others
