Shut off main water to home. Then check if a clip is guarding the nut to nut threaded connection the use 2 wrenches to un screw. Cover tools "teeth" with tape or thin rubber to prevent marking on chrome/etc finishes.
Should be able to turn water supply off to faucet and trace the line connecting the pull-out faucet. Remove weight in center on hose line this weight helps retract the faucet head in with the line. Remove it and disconnect the line connection and remove the old one.
Since you are replacing the Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray faucet, bend the water supply lines out of the way, and then use a standard basin wrench to remove the nut.
To get full pressure you need to pull the wand away from the base. Then remove the wand from the hose becareful not to loose the washer. When the wand is removed look down the wand you will see a plastic part. That plastic part is a flow restrict-er. You need to put a screw in the restrict-er and pull it out. When it is out put wand back on the hose then you will have full water pressure.
