Question about Toshiba TEC B-SX4 Thermal Label Printer
Barcode printer type: TOSHIBA SX4 sensor setting for thermal transfer / transmissive error msg paper jam. how to see the sensor?
Posted by ds1053 on
pkwc
    Champion:
  • 254 Answers
Diagnostic boot
Feed PAuse button pressed and switch on Keep button prressed until message (1)Diag ...
with feed goto 5 sensor adjustements.
Pause to enter the menu
select the sensor you want to calibrate!.
Feed or restart button for 5 seconds until a star appears.
Switch off and on the calibration is stored in Eprom
Posted on Aug 05, 2011
  • Ron Broekmeijer Sep 24, 2013
    After above procedure without stickers, put in some stickers and find the treshold which should be between 0,8 and 2,3 Volts now go to section (3) in the menu and set the threshold for 1,4 Volts on the transmissive sensor
Hello my Toshiba B-Sa4TM printer states paper jam but there isn't anything jammed? i don't have a clue how to calibrate the sensors any ideas??
You may have a mis alignement of the detecting cells.
The arrow on the top part of the cells should be on the round hole on the bottom part. (Green plastic mecanism)
Nov 04, 2013 | Toshiba TEC B-SX4 Thermal Label Printer
B-sx4t keep paper jam, i was replace the media sensor ,sensor cable and mainboard but still paper jam.Any one experience this?
Paper jam:
- The label is not correctly declared.
- Callibarate the sensors (5 sensor adjust) diagnostics menu
- the silicoe support is too thick.
Dec 05, 2012 | Toshiba TEC B-SX4 Thermal Label Printer
Toshiba TEC B-SX4 paper jam
Size problem or type of material problem or recalibrate the sensors.
All in the owner's manaul
Mar 05, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
Hi, I have a TEC SX4 printer which im trying to
There is usually a setting in your label software or printer driver that lets you choose between thermal transfer printing or direct thermal printing. Make sure your setting is on direct thermal.
Hope that helps !
Aug 12, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
Ribbon Error
According to the user's manual this message indicates a problem with the ribbon sensor. As a test, set the unit for thermal direct printing and attempt to print a barcode. You will not see the code if yoiu are expecting thermal transfer, but the paper/label should feed like it is printing. That will indicate that the printer is functioning. At this point, the sensor needs to be replaced.
Hope this helps,
Dan
Apr 22, 2010 | Toshiba TEC B-472 Thermal Label Printer
Paper jam error message
This problem is a detection problem, due to a bad sensor selection or incorrect label size.
If the labels are white labels with a separation between each, select TRANSMISSIVE. If the labels are preprinted, select the TRANSMISSIVE PREPRINTED LABELS and set the threshold doing this.
With the printer in ONLINE, press PAUSE once, the message PAUSE appears in the display, press and hold on the PAUSE key, TRANSMISSIVE is displayed, release the key and press PAUSE until labels starts to feed, let feed some labels (5 or 6) and release the key. Press Restart and start to print.
Dec 08, 2009 | Toshiba TEC B-SX4 Thermal Label Printer
PAPER JAM
Paper jam on this printer have several causes:
- The size of the label is not correct (The legth mainly)
- The type of Sensor is not correct.
Transmissive or reflective.
- You are using preprinted labels which affects the detection.
To solve this you have to callibrate the sensors for the preprints. Check your manual or contact us.
- there mays not enough contrast between the liner and the labels. You must check the sensors
- Check if the sensors are correctly aligned. You may misaligne the top and the bottom sensors
Feb 23, 2009 | Toshiba B-SA4TP Printer
TOSHIBA B SX4 thermal barcode printer and Solaris 10
First of all change the escape caracters used to define the tpcl commands.
(2) parameter
code auto to {|}
Substitute in your code ESC ={ Lf = | and Nul =]
The printer will ignore the other control caracters
May 07, 2008 | Toshiba TEC B-SX4 Thermal Label Printer
Toshiba TEC B-SX4 Thermal Label Printer Logo
Top Toshiba TEC Office Equipment & Supplies Experts
k24674
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
