Question about Mitel 5224 IP Phone
How do i manually configure and ip address for the mitel 5224 ip phone?
Posted by oronde_holde on
Mark Compton
    Sergeant:
  • 378 Answers
Press and hold the up arrow.
Configure Phone - Yes
network parameters - yes
press no until you see "change" and press yes.
You will need to set the following appropriately.
IP address, Subnet address, default gateway, ICP controller address, TFTP address, VLAN ID, VLAN priority, DiffServe Value, DNS address.
Normally it is not necessary to set the phone static except for testing. If your network and DHCP server is set up properly, you are not gaining any benefit for setting it static.
Also, you should find out what the other IP addressess are that are static on the Voice subnet. Along with that, you will need to know the DHCP range. These are needed so you don't assign a duplicate IP address to your network. Assign the phone to the wrong device could do great harm to your network. Assign it to use the same IP address as the phone system and none of your phones will operate.
Use with caution,
Mark
Posted on Apr 04, 2011
Phone is displaying DHCP:discovery boot ver 02.01.00.04. Mitel phone was working perfectly until router changed to BT Hub. What can I do to resolve it?
You can download the TNA analyzer to test ports. Or your router is not giving dhcp to the phone. You can try to statically assign an IP address to. The phone.
Feb 18, 2013 | Mitel 5224 IP Phone
How do I clear a Mitel 5224 which is displaying locked out
Set type is wrong or the phone is a IP device only
Jan 14, 2013 | Mitel 5224 IP Phone
How to set time on a mitel 5224 phone
Need to get access to the phone system to change the time
Nov 02, 2011 | Mitel 5224 IP Phone
The phone is saying that option 128 is missing im not sure what this means
This means that the phone is expecting to receive a tftp server address from the DHCP server to download it's configuration files, but the DHCP server is not providing this information. Please check with your Systems Administrator to make sure your IP PBX or another server is housing the configuration files and the tftp program or daemon is running, then have them add the tftp server setting to the DHCP scope for your network.
Feb 22, 2011 | Mitel 5224 IP Phone
Can i connect a mitel 5224 ip phone to a standard land line connection.
only with a "Line Interface Module". This is a module that attaches to the back of the phone. Once attached a button will need to be programmed to allow it to work.
The phone will still need to connect to the telephone system - SX200ICP or 3300/MCD.
Dec 17, 2010 | Mitel 5224 IP Phone
Hi =) I have a mitel 5224 which i connect to my
the stand requires configuration to tell it how to connect to your Wireless router. The default IP address is 192.168.1.20
The firmware should be upgraded to 2.0.3.ap51. This provides for better security and more options.
Nov 09, 2010 | Mitel 5224 IP Phone
What is the pinout for the headset port of the mitel 5224 IP phone?
No idea. Contact Plantronics for a headset. This phone will support a variety of headsets. www.plantronics.com.
Mar 04, 2010 | Mitel 5224 IP Phone
Mitel 5224 IP Phone Logo
2,732 people viewed this question
Top Mitel Computers & Internet Experts
Vincent G
Vincent G
Kelley Hopper
Marvin
Marvin
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
