Question about Hobart HL600 Legacy Stand Mixer
Hobart HL 600 Mixer Error code 20, any Ideas?? Motor starts and runs for approx 20 seconds then stops and error code E20 is displayed.
Posted by paulyarmy8 on
5 Related Answers
Anonymous
  • 640 Answers
SOURCE: Hobart H-600-T Mixer Shuts down while mixing bread dough
What you replaced were the contacts on the overload,correct?These 'heaters' look like springs?If so you have other issues.I'm a hobart tech and repair these mixers often.Are you mixing pizza dough?
Posted on Mar 07, 2009
Anonymous
  • 135 Answers
SOURCE: Need oil/grease for Hobart 20 qt. mixer
Hi. Your A200 is in need of service. The grease's lifespan has expired. There are two ways of doing this. First, the expensive way. Call for a Hobart Tech to come and service the mixer. This will take about 4-5hrs to service at a rate around $100.00usd per hour, plus the cost of parts. He/she will need to change all seals, remove old grease and oil, check all bearings and gears for excessive wear and replace as necessary, this includes the planetary gear.
Now for the affordable solution. Unplug the mixer, remove the top cover. Gently use a small screwdriver to pry off the two circular metal dust caps found on the transmission housing, use a good flashlight to determine, through these openings, the quality, quantity and condition of the grease inside the transmission case. If there's a lot of oil you can remove much of it a bit at a time by using a wire coat hanger to which you can attach bits of cloth to absorb as much oil as you can. Once oil is removed, add new grease through these same holes until full (Chevron FM ALC EP-2, food grade lube). Run the mixer for a couple of minutes to distribute the new grease. Fill to the top once again and replace dust covers. Remove planetary, clean, inspect change seal and re-grease.
OPTION (mechanically challenging) You can do a more thorough job by removing the trans. cover completely, removing the 3 gear shafts inspect all bearings and gears, change seals on mainshaft and planetary. Remove old grease and oil, clean gearshafts and gears. Parts drawings are available from www.hobartservice.com It's free to register and then locate your parts drawings. Be sure that you have the correct files for your Model #, ML# if there is one and Spec.#, all found on the info plate.
When disassembling, take a digital photo of every step and lay the removed components on a piece of cardboard in the removed sequence. These practices will become valuable during re-assembly.
If this solution has assisted you, please rate it. ricardok45
Posted on Mar 20, 2009
Anonymous
  • 1304 Answers
SOURCE: how do you change the oil in a hobart h 600-dt
there is an oil case drain pulg under the top by the clutch, you can drain the motor housing through there, \
i have used 5w30 in a pinch
but it would be better if you ordered hobart oil from the website
its cheap but very very good
Posted on Oct 16, 2009
Anonymous
  • 110 Answers
SOURCE: PLEASE HOW TO CHANGE OIL OF A HOBART MIXER
underneath trans. you will find a drain plug remove, drain oil,replace plug ck the sight glass @ this time if not clear would recommend replacing glass remove top cover where the front cover screw theaded into remove that is your fill hole. add new oil till you hit level line in sight glass,reassemble
Posted on Jan 09, 2010
Anonymous
  • 110 Answers
SOURCE: what is error code 99
error 99 stands for communication fault between timer board and the sr drive.there are 5 things that can cause this error.1.rs-485 cable disconnected or malfunction 2.1 con monitordisconnected or malfunction. 3.run/stop wiring disconnected or malfunction. 4.timer board malfunction. 5.sr drive malfunction. hope this helps, dont forget to vote, thanks, monomoy
Posted on Feb 05, 2010
Why My Hobart A200 20 QT Mixer ML #104858 Motor Is Smoking?
I think... without knowing that motor... that the capacitor is a start capacitor, and that the start switch may be trying to "start" the motor full-time instead of switching it out of circuit after it figures that the motor has spun up. I may be wrong - that design may be a capacitor-run motor (similar to a three-phase motor) - but I'm betting it's a start-only capacitor.
If you know someone with a capacitance meter, you could check the capacitor - for both capacitance (to be sure it matches the label) and leakage. Easy way to write that one off. Alternatively, you could rig it such that after the motor's wound up you could manually disconnect the capacitor and see what happens - either the motor stops or else the smoking issue stops.
Whatever you do, don't let it smoke very long. The varnish on the windings is only so thick.
Jul 31, 2014 | Hobart A200 Stand Mixer
Hobart Legacy mixer error code oc3 will not run.
Hobart mixer, HL300, stops and flashes as oc3, wounded what is broken?
Dec 08, 2010 | Hobart HL600 Legacy Stand Mixer
Our hobart HL 600,no display in speed and timer,even there a 24vac,supply in timer controller,only bowl up and down are working
If you have 24 VAC to the timer board and still have no display, then you need a new timer board.
Aug 02, 2010 | Hobart H600 Stand Mixer
What is error code 99 for a hobart HL 600 mixer?
Jan 29, 2010 | Hobart HL600 Legacy Stand Mixer
Keep getting error code 23 when trying to start mixer
i will try to help, always include ml# with problem description on any hobart pc. of equip. which is located on the info. plate. there are 2 v.f.d.for this mixer ,sr drive being 1st generation, and gen. elec drive 2nd generation, on the sr drive err23 indicates a motor stall condition there are 6 most likely causes for this err. 1st, batch size too large,ck. capacity chart. 2nd,encoder malfunction. 3rd,motor malfunction. 4th,drive malfuction. 5th,1 con coil malfunction. 6th,2 cr malfunction. if this does not help, repost problem and i will ck. to see if i can be of anymore help, please dont forget to vote for me thanks, monomoy
Oct 05, 2009 | Hobart HL600 Legacy Stand Mixer
HOBART HL 600 NOT WORKING.SPEED & TIMMER ALL LIGHTS WORKING BUT NO MOTOR FUNCTIONS.
What'd ya do to that poor little workhorse? You need a Hobart service guy. The power is not getting from the switch to the motor. Could be a disconnected wire (on the simple side), could be the start capacitor. Did you turn the timer on? If you don't the mixer won't run! That is a 220V, don't stick your hands in there when it is plugged in.
Sep 01, 2009 | Hobart H600 Stand Mixer
Electrical connection of hobart h600
it requires 3 phase with ground it is a four wire system
Jul 24, 2009 | Hobart H600 Stand Mixer
Hobart 20 QT. mixer (HL 200) will not operate on a GFCI receptacle.
you need to replace the gfci,the older gfci's interpret these frequencies as a shock hazard and shut off power to the circuit.you can buy @hobart, part#913053, that should solve the trip problem. dont forget to vote thanks monomoy
Apr 05, 2008 | Food Mixers
Hobart hl600 mixer
I know what these codes are: code 19 is that phase c is over current fault and code 23 is a motor stall fault.I would start by making sure you 3 phase wiring going into the mixer is there.I service these mixers as im a service tech for hobart.these units are very detailed and i can walk you thru some things to check but if you have an electrical problem you most likley will have to call a hobart service tech because we have special equipment to diagnose the fault.let me know it may be something simple as these mixers are usally maintenance free.
Nov 14, 2007 | Hobart HL600 Legacy Stand Mixer
Hobart HL600 Legacy Stand Mixer Logo
Top Hobart Food Mixers Experts
Ross Keen
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
