Amana AER5712AA Electric Kitchen Range Logo
Posted on Feb 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oven won't get hot - Amana AER5712AA Electric Kitchen Range
Anonymous
Level 2:
Champion:
  • Expert 235 Answers
  • Posted on Feb 11, 2011
Anonymous
Expert
Level 2:
Champion:
Answers
235
Questions
Helped
75801
Points
387
Generally the oven element is the most common thing to go followed by burnt wiring at the oven element terminals. If this oven has an electronic timer the timer needs to be in manual mode for the oven element to turn on. If the oven indicator light is coming on then it will be in manual mode and the element or wiring as mentioned above will probably be the problem. If the oven indicator light is not coming on then the timer is probably on auto.
GE electric oven won't stay hot
Google GE electric oven Model number: ? Manual
Jan 15, 2018 • GE Ovens
My oven gets too hot and won't turn back down
Sounds like a problem with the oven thermostat. You will need to meter check it and see if it is closing at all. If not replace the thermostat.
2answers
2helpful
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Fan turned on by self, won't turn off
The unit has a temperature sensing device that turns on the fan if it gets too hot...if it is very hot in your house it could turn this on...
If it is not overly hot then the thermistor or the main control board have gone bad and are reading an incorrect temperature...
heatman101
My microwave will turn on but it won't get hot.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
F2 warning, oven won't turn off
Hi leelarupa,
The F2 failure code indicates that the oven is too hot. To correct this error you need to replace the oven temperature sensor.
Hope it helps.
Thank you for using FixYa.
Top Amana Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
