Question about Intermec EasyCoder 4420 Thermal Label Printer
We have 2 Intermec 4420 printers. We printed the same label out on both printers. Our scanner reads one but won't read the label from other printter. Why do you think this is happening?
Posted by gege42 on
pkwc
    Champion:
  • 254 Answers
If you use the same resolution, and the same print speed, check the temperature use to perform the transfer. The barcodes are not correctly printed on one of your printer.
Posted on Aug 04, 2011
I have two identical 4420 printers. suddenly one prints much slower than the other. What mechanism needs replacing? I don't have any manuals or anything
I think parallel port issues. Assuming your fastest printer connected to onboard parallel port. connect slow printer on pci2parallel port.
Ink wont transfer to sticker on a 4420 intermec
Make sure the "carbon" is down so that it gets transfer to the top of the label. I can check this by just scratching it with your fingernail and it should rub off. If you are sure you have the media loaded correctly and the ribbon and label are a compatible match then you might just need to increase the heat or darkness setting on the printer. Some ribbons require a higher heat setting to transfer the carbon.
Good day, I need the Intermec 4420 service manual, could you help me?
Contact Intermec Support at
Intermec Repair Center
13509 Southpoint Blvd. Suite 100
Charlotte, NC United States
28273-6759
Telephone: 800-755-5505
Intermec doesn't put service manuals on their website. You may run into issues if you are not Intermec service certified.
Cheers
Billy Barcode
1-866-306-7226
2answers
Printing Bar Code Labels from Intermec 3400
I am using Smartforms with Intermec printer 3400-e and it works in the correct way.
What is the software that you use to build the layout of the label? In my case Loftware.
What is the code to print the Barcodes.
In my case Code 39
2answers
Empty/pause light on will not print
Intermec Sells a Cleaning Solution that is like a pad of labels, use it and it auto cleans the sensors.
Will not print labels
you have connected two printers on a data switch.right.
1. Print test page through Printer driver.
2. If you are using command for printing on Intermec printer, you should not use generic printer.
3. Interchange the cable connected to printers
1helpful
Intermec 3400 label printer
try here they oft times has a few good referance materials http://epsfiles.intermec.com/eps_files/eps_man/064678.pdf
Intermec EasyCoder 4420 Thermal Label Printer Logo
Top Intermec Office Equipment & Supplies Experts
Paul Bade
reference30
ENFORCER
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
