Question about A4tech A4 Tech KBS-8 Anti-RSI Multimedia Keyboard
I need the driver for my keyboard - A4tech A4 Tech KBS-8 Anti-RSI Multimedia Keyboard
Posted by madalinteror on
Fujitsu ah 532 keyboard driver
Keyboard drivers are not downloaded, what makes you think that you need them, drivers for keyboard, DVD devices and simular are built in to the OS, you could try to plug in a USB keyboard and delete the drivers that are installed then reboot the machine, should reinstall the needed drivers ok.
Oct 27, 2013 | Fujitsu LifeBook AH532 Notebook
Ikbt-50 driver needed
You don't need a driver! This is a Bluetooth keyboard. What you need to do, is pair it with your Bluetooth device.
First, charge the keyboard. Enable Bluetooth on your device. Now, push the small black button marked "ID" on the back of the keyboard. The button needs to go in pretty far. This will generate the Bluetooth code needed to pair your Device. You need to enter the four digit numerical code generated by the keyboard. That's it! You are paired!
Oct 25, 2013 | Case Logic IKBT-50 Bluetooth Keyboard...
Need keyboard driver for windows 7
The majority of keyboards and mice will work simply by plugging them in to a Windows 7 computer. Only some special gaming keyboards and some wireless keyboards will require addition drivers to function. If this is the case go to the manufacturers website and look up your model and download and install the appropriate driver. One way to see if you are missing drivers is to look in Device Manager (Right click Computer, select properties, select Device Manager on left pane) If you have a yellow ! or ? for your keyboard then you do indeed need drivers installed. If it is listed under keyboard and mouse then you most likely have a problem with the keyboard itself and should replace it.
Feb 04, 2012 | Computers & Internet
Drivers abacus drivers usb
Hello hadi_kamalif, I've given you a "Link to the Website,"
where you can {Download the Drivers}, you need!
Please select from the 'list', exactly what you need.
*Note: Before you 'download the drivers'.
Disconnect the "Keyboard."
"Download the Driver; install them.
Restart the computer.
Connect the Keyboard.
The "Keyboard should be recognized, and 'function properly."
If this 'solution' help? Please return a "Helpful Rating."
If you need futher assistance?
"Write a 'comment', I'll be here!"
"Best Regards."
Click here for "Drivers" http://www.dicota.com/start.php?menuId=8-page_download_treiber
Aug 13, 2011 | Dicota Abacus (Z2758Z) Keyboard
My top row of buttons on my dell keyboard is not working. the calculator button and other buttons? weird any ideas?
It says that the drivers for your keyboard is not installed...
you need to Install the drivers that came along with the Keyboard...
If it doesnt comes with a cd search in dell site and download the drivers...
This happens because, the default drivers for keyboard will be present in the database of windows, so you wont be facing any issues in using the keys...
But for using the special keys, u need to have drivers...
Dec 08, 2010 | Dell Wireless Keyboard Optical Mouse w0147
My computer stopped recognizing my wireless keyboard & mouse. Says it's missing a driver or that the device is malfunctioning. Don't think it's a battery prob. Do I need a new driver?...
Uninstall the Keyboard driver.
Unplug the Logitech keyboard.
Plug the Logitech keyboard back into the computer.
Windows should recognise the keyboard and/or the mouse.
Place Logitech setup disk in drive.
Reload the drivers...
The drivers sometimes corrupt themselves..
You might download the latest drivers for your keyboard/mouse.
Jun 28, 2009 | Logitech Wireless Access Duo Optical...
I need a driver for acer usb keyboard
usb keyboards generally dont need drivers... chek any disc provided with the hardware or u might be using a low speed usb port
May 17, 2009 | Acer NSK8458AN Keyboard
Acer M1100 keyboard drivers for Vista
you want to use multimedia keys then you have to install the drivers otherwise there is no need to install the keyboard and mouse drivers, they will work fine
Nov 27, 2008 | Acer Aspireā„¢ T180 PC Desktop
Corrupt keyboard drivers
Generally, if you are using a corded keyboard, it should automatically get recognized and the built in Windows drivers should work.
If you are getting a wireless keyboard, make sure you have the latest driver/software and have that installed.
Apr 15, 2008 | Gateway 2520915 Keyboard
A4tech A4 Tech KBS-8 Anti-RSI Multimedia Keyboard  Logo
Top A4tech Computers & Internet Experts
Carlo Barzo
Carlo Barzo
k24674
Resolution IT Dubai
Resolution IT Dubai
Are you an A4tech Computer and Internet Expert? Answer questions, earn points and help others
