The little pipes that spray the windshield washer fluid clog very easily. Use either a very thin piece of wire or a very small drill bit (a welder's "tip cleaner" works perfect!) to clean out the sprayers. Use only 100% bottled washer fluid and not tap water since the minerals will clog up the sprayers.
Make sure the rubber hoses between the pump and the sprayers did not pop off or split. If your fluid level goes down but you get no spray it is going somewhere it is not supposed to.
When you activate your windshield washers, you should be able to hear that little pump run- it makes a very distinctive sound. If you do not hear it, there is a wiring problem.
