SOURCE: Blue/black vertical line in the middle of screen
Sounds like a bad connection on a ribbon cable or plug comming or going to the LCD display. This is something you should not try to fix as these circuits are very very fradgile and you can easily break or tear a ribbon cable . Call the manufacturer to get a tech to assit you. Good Luck
SOURCE: Samsung VP-D101 blank LCD display
John, Samsung has been having very serious problems with the CCD imagers in their camcorders for some time now. I would give them a call and let them know how disappointed you are in the camera. Almost all manufacturers having this problem are repairing the cameras at no charge to the customer. Good luck to you! Joe Weibel customelectronics.org
SOURCE: LN-T4665F 46 in. LCD- Black Line across screen
The set is under a year old and is under warranty. The LVDS cable inside these sets have a history of coming loose. The problem could be the panel. Either way, the set is the problem and needs to be looked at. This set is worked on in the home and does not need to be taken to a shop, so, you can still use it. Contact Samsung at: 1-800-SAMSUNG Hope this helps.
SOURCE: Samsung VP A30 - Instructions
You can plug it straight to a PC via a cable with stereo lack at one end to go into the video camera, and a mono jack (sound card) and phono (TV card) at the other end.
SOURCE: No Display On LCD in VP-D351 Samsung camcorder
hi ..had the same problem..had advice from this site two weeks ago..which was spot on..the lcd screen ribon has brocken.. its available from partmaster..www.partmaster.co.uk...part required..no SAMAD9706489A..£11.49.. took me half hour to take camera apart (carefull.y) 10 min to put back togerther.. works brilliantly.. good luck.. Need futher help email me..stefjanet @yahoo.co.uk..
