Usually the paper source is set to Auto in Printing Preferences so if you put paper in manual tray it will feed from manual tray and will override the tray 1 selection. If you specifically want to change it to a tray disabling tray 1 you can do so if you go into Control Panel, Printer and right click on the printer and select Printing Preferences and then on Paper menu change the paper source.
This message indicates that the scanner has been disabled cannot be used. The MFP must be powered off and then press and hold the check and the right button and turn on the printer to access the configuration menu
1. In the configuration menu, use the arrow keys to scroll to the Disable Scanner menu item.
2. Press check button.
3. Use the arrow key to scroll to the desired setting. The options are Enable ADF/FB, Disable ADF/FB, Disable ADF only, Auto Disabled. (Please select Enable ADF/FB)
4. Press check button.
5. Press BACK button.
6. Scroll to Exit Config Menu.
7. Press check button. The device restarts.
8. Try running a copy from the ADF and flatbed.
For further assistance, please contact Lexmark Technical Support.
