Question about Arris SURFboard SB4100 Modem
192.168.100.1 is not accessing my router - Arris SURFboard SB4100 Modem
Posted by blazalot on
Anonymous
    New Friend:
  • 88 Answers
Try 192.168.0.1
192.168.2.1
and finally try 192.168.1.1 instead of 192.168.100.1
Posted on Feb 10, 2011
Please I cannot connected to internet
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
May 26, 2011 | Computers & Internet
I'm trying to ad a mac ipad to my belkin54g router.. i believe the router is locked to stop access. how do i unlock the router
Are you able to access the configuration utility inside the router or are you asking how to do a hard reset?
Mar 03, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I lost my cd for setup ipls help me this is my serial number of my netgear 1um8977f03f04tnx
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point's DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to 192.168.1.99.
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL: http://192.168.1.99
  9. Connect one of the wireless router's Local (LAN) ports to your existing network
Feb 21, 2011 | NetGear WGR614 Wireless Router
How do u access the wifi from your home at&t 2WIRE701 router on an ipod touch
1. you will have to access the routers permissions page.
You should be able to access the admin page through a browser page using 192.168.1.1 or 192.168.0.1 . Check your user manual for the correct IP address to access the Admin page.
2. You will need to allow the I POD to access the internet via your router with either the MAC ( Media Access Control ) address or be an IP assigned by the router.
3. You will need to set up your (DHCP) Dynamic Host Control Protocol ) and your DNS (Domain Name Service / Server) automatically.
Sep 28, 2010 | 2wire (1000-400108-001) Router
Cant go to setup for my router 192.168.2.1
you can't access your router IP address? are there any errors? have you connected your computer to your router using ethernet while accessing the router? cause if try accessing your router wireless it will not work this should be done hard wired using an ethernet cable ^_^ also have you tried resetting the router to default by pressing the pinhole on it press it for 5-10 seconds then let go try accessing the router again ^_^
Jun 06, 2010 | Belkin (F5D5231-4) Router
Two access points don't work
1. check the distances of the access points.
If over 300 hundred feet you will loose.
2. check the main router to verify access points are configured in it.
Apr 19, 2010 | Zyxel Prestige 600WH Wireless Router...
Need basic step-by-step instructions on how to install my router.
  3. Reboot the PC.
  5. Go to the LAN IP menu and disable the wireless access point’s DHCP server by unchecking Use router as DHCP server.
  9. Connect one of the wireless router's Local (LAN) ports to your existing network.
This completes the wireless router/access point configuration.
  • You can now log in to the wireless router/access point at its new address of http://192.168.1.99 and configure wireless features such as WEP and Access Control List
  • UPnP, DMZ, Port Forwarding, and Port Triggering are not used on the wireless router/access point, and it doesn't matter how they are configured.
  1. Configure the LAN IP address to be within the same subnet as your PCs.
    • Take care not to use an IP address already being used.
    • Limit the number of addresses in the DHCP range and assign an IP address outside of the range to the router you want to use as the Access Point.
  2. Disable DHCP on the wireless router/access point.
  3. Connect one of the LAN ports on the wireless router/access point to a LAN port on the Router.
  4. Configure the SSID and any security settings on the wireless PCs to match the wireless router/access point's SSID and security settings.
a. SSIDs must be the same on all wireless devices. (These are case-sensitive: netGEAR is not the same as NETGEAR.)
b. Tip: Make sure the wireless PCs can connect before configuring WEP, WPA-PSK, or other wireless encryption.
Jan 02, 2010 | NetGear WGT624 Wireless Router
I have a Linksys wrt546 router. How do I enter the routers IP address.
First connect your router to computer with ethernet cable then you can access it with defaults link
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then you can see configuration page of router.
If are not able to access it then go to start menu then type in run "cmd" then you see command propmt
Type in prompt "ipconfig /all"
then gateway ip is your router ip so you can access router with that gateway ip.
Still not able to access then reset router .
Press RESET button for 10 seconds it is in back panel of router.Then you can access it with above link.
Let me know if you need more assistance.
Thanks.
Oct 02, 2009 | Linksys Wireless-G WRT54G Router
Can I use the Netgear Rangemax wireless router as an access point?
Yes you can use it as an access point and hook it to your existing router, since this is a wireless router and can work as a wireless access point on your network............
Nov 03, 2008 | NetGear RangeMax WPN824 Router
Belkin 802.1 g
it is usually 192.168.1.1 to access that routers interface. To find out for sure:
1.Click on run
2. type in cmd and hit enter
3.type 'ipconfig' in the black box that popped up
4. the 'Default gateway' is the address that will be used to access the router page.
I would go to www.portforward.com to learn how to properly forward the ports for your router.
This should help!
Jan 01, 2008 | Belkin (F5D7230-4) Router (587009)
Arris SURFboard SB4100 Modem Logo
Top Arris Computers & Internet Experts
Len
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
