Question about Gateway GT5676 Desktop PC
I can't get a signal from my desktop to my hdtv when I use the hdmi port. The desktop is a gateway GT5676
Posted by snuggler40 on
  • snuggler40 Feb 10, 2011
    I have the tv hooked to no other inputs as I am only going to use it as a monitor. I have scrolled thru the input on the tv and got to its only HDMI position. The screen shows no signal
Kastl & Kastl Associates
    New Friend:
  • 27 Answers
First, make sure the computer port is working in the computer by going to the device management ICON in control panel.
Once you check that, make sure you have set up your preferences in the TV to allow "INPUT" from the HDMI port. If you have more than one HDMI ports make sure you have the correct number listed. This is a common error. It would be the same if you are running a DVR with an HDMI cable, you need to set up the TV. Normally you hit the "INPUT" button on the remote control and a list pops up. Scroll over with the arrows to the correct HDMI port. You will likely need to do this again to get back to the cable input once you are finished with the computer connection.
Posted on Feb 10, 2011
Gateway zx6971 has a in HDMI port BRAVIA HDTV has a VGA and HDMI ports How do I CONNECT my P.C to the T.V
either way hdmi will be the easiest otherwise u have to buy a new cable for vga and go hdmi on tv
May 04, 2013 | Gateway Zx6971-Ub30p 23 Touch-Screen...
How can I get my Gateway desktop to recognize my Projector?
it has to be set up as an additional monitor/display. so, there are settings to set up the displays as either twins, unique seperate or something like that. have not had to do it. but i know that the graphics have to be able to recognize what format the signal is. pc settings change and graphics setttings change. have you done both? the projector should have had instructions? if not look for the manual online.
Aug 23, 2012 | Gateway Computers & Internet
I cant run my gateway GT5676 pc in normal mode with Samsung TV / Monitor
If I'm understand you correctly you said you have the HDMI Cable and the VGA Cable comming from the Computer to the TV. You should only have one cable. Either use the HDMI from the computer to the HDMI to the TV or use the VGA from the Computer to the VGA on the TV. Once you have the cable connect select your input on the TV. If you have the VGA Cable connected your input to select on the tv will probably be PC or Computer. If you use the HDMI Cable your input to select on the TV will be HDMI.
One you connect the cables and select the input try rebooting the computer and the video might show up automatically on the tv. If not you will have to hit the FN (Function key) + the correct (F1 thru F12) key that corresponds to the external display. The correct key will probably have CRT/LCD on it or it might have the icon of a display. Press and Hold the FN key then hit the correct key (F1 thru F12) that toggles the display. The display will toggle on 3 setups (Computer only, TV only, both the TV and Computer).
Now as for not being able to boot up normally that's another issue.
Apr 06, 2012 | Computers & Internet
What is the second hdmi port surrounded in orange on the back of my gateway dx4320-17 do? it doesnt work when connected to my monitor so is it an hdmi input? and would i be able to connect my ps3 to it and...
I presume by second HDMI that you've got an additional Video Card in one of the expension slots (Item 10 at the link below) with another HDMI output
http://support.gateway.com/s/desktop/2010/gateway/dx/dx4840/DX4840rv.shtml
The HDMI surrounded by orange is an ouput but if you've got and additional Video Card then this build in HDMI would normally be deactivated.
Sometimes the problem relates to the screen resolution you've got your computer set to as this needs to match your Monitors HDMI Input i.e.1280x720 or 1920x1080 as detailed at the link below.
http://hd.engadget.com/2006/02/08/how-to-connect-your-pc-to-your-hdtv/
Jul 26, 2011 | Gateway DX4300-03 Desktop PC
Gateway DX4720-03 desktop the HDMI stopped working when it's connected to the tv. Message on tv says no signal says no signal. How to repair?
Make your hdmi port a separate monitor in your display settings. If that didn't help leave a comment and ill try to help you again.
Jul 02, 2010 | Gateway DX4720-03 PC Desktop
My GT5676 goes black in the middle of things. I
have you tried replacing the monitor or the LCD? if not please do so then try.
May 15, 2010 | Gateway GT5676 Desktop PC
Is it powering off, or is the display just going black? Check to see if the keyboard is still active - can you see the Caps Lock light go on/off as you toggle the key?
Mar 28, 2010 | Gateway GT5676 Desktop PC
Installed new memory on gt5676, lost video output, have constant tone?
pput old memory back in if it works then you have a bad memory chip or the wrong kind or not matched up.
Nov 26, 2009 | Gateway GT5676 Desktop PC
Using an HDTV as the PC monitor via HDMI
HDMI carried audio as well as video... Make sure it doesn't have an AV audio coming into the same AV channel
Jun 05, 2008 | Computers & Internet
Gateway GT5676 Desktop PC Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
