Question about Kenmore 98702 Stacked Washer/Dryer
My 27inch Kenmore washer model # 97812 got overloaded in a load, shut down for the 30 minute cool down and ever since then when I turn it on to start a load the agitator starts going while it is filling with water. It does the same when it is time in the cycle to rinse so things are getting caught under the agitator and making it stick and overload. It never did that before. I unplugged it with the hope it would reset it and after 1 hour unplugged it didn't fix it. Help!
Posted by lizeb1 on
Johnny Ramirez
  • 116 Answers
Check your pressure switch ...or even the pressure hose is probably clogged...Reason for agitation issues.
Posted on Jun 08, 2017
5 Related Answers
catriver
Ron Marek
  • 878 Answers
SOURCE: Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Posted on Apr 27, 2007
Anonymous
SOURCE: lg wm2032hw
check the pump filter and if necessary clean it up.
if you stop the programme and hold the start/ pause button for 3-5 sec the programme will cancelled and the drain will work.
if you hear a slow noise from the pump it may be blocked with external objects from your clouthes pocket,
so you need to contact a repairman.
Posted on Jan 28, 2008
Anonymous
  • 4 Answers
SOURCE: shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Posted on Sep 02, 2008
docjohn174
john gagnon
  • 943 Answers
SOURCE: kenmore top load washer 110
hi thanks for the question i would check the lid switch very common for that make thanks the appliance doc
Posted on Sep 27, 2008
Paulo
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
Kenmore elite stackable starts and after 30 seconds stops then after 2 minutes starts again with a huming sound
Your talking about the dryer right? If so, the blower is not working. Unit has "high temp" safeties built in to shut dryer off if overstepped. No blower to force air over heated coils, causes high temp causing unit to cease working until cooled down then it will start and stop again after another 30 sec.
Nov 11, 2013 | Frigidaire Kenmore Washer Tub to Pump Hose...
Machine will not start - looks like it needs a reboot - too many towels - machine struggled with spinning and shut it self down
that means motor over heated there is no reboot let cool down unplug washer and rerun spin cycle with less in about 30 minutes towels
Jan 26, 2011 | Kenmore 24032\24036 Top Load Washer
Top loading Kenmore washer runs for a few seconds then shuts off
It's quite possible, however,
If you're mechanically inclined, I'd check the motor, transmission and pump first.
See the following Whirlpool / Kenmore Service manual for top load, direct drive washers and it's trouble-shooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
See the following for how to pull the cabinet, pump, motor and transmission to check them all.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
YOU DON'T HAVE TO PULL THE TUB.
Mar 15, 2010 | Kenmore 43142 Front Load Washer
Kenmore 800 dryer shuts down after running down to 40 minutes on the timer. When I restart it at that point it runs for about 30 seconds and shuts down. If I turn the timer back to 90 minutes it runs down...
Sounds like you may have a bad motor. If the motor is overheating it will shut down on its overload.
If its a shorted contact in the timer you could mark the spot where it stops and restart it again. It should stop exactly at that point.
Jan 22, 2010 | Kenmore Dryers
Kenmore 80 series. RUNS LOUD, THEN TURNS OFF AND RESETS...
you have something gotten into your pump ,,, it trys to drain and spin but overloads the motor and shuts down till the motor switch resets .... remove the pump and take out whatever gotten in it and if that not possable replace the pump.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
KENMORE DRYER HEATING PROBLEM
You need a new Motor. The thermal overload on the motor shuts it down,until motor cools down.
Nov 22, 2008 | Dryers
Kenmore Dryer works for about 20 MINUTES, not seconds
SD, doesn't sound like the same problem. Yours sounds more the like motor kicking out on overload and when it cools down you are able to start it again. The thermal fuse and high limit TCO are non resettable so you can rule them out. You are going to have to check some things out. Make sure the rollers and pulley are not binding. The blower wheel is not binding. These things will cause a drag on the drum and put a heavy load on the motor. Catriver...post back
Feb 12, 2007 | Kenmore 64902 Electric Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
505 people viewed this question
Michael Thomas
Michael Thomas
Paul Carew
Nicola Conroy
