Question about Korg Mini Kp Kaoss Pad
I just bought a korg kaoss pad 3 dynamic effect sampler on ebay. When i turned it on it worked however the volume only worked on one speaker so I opened it up due to I have no proof of warranty nothing and I'm the only one who can attempt to fix it. Anyways, so i removed the first board and pulled it out to look at it and then I stuck it back in and now it doesn't power on? I work with computers and phones and all, but it makes no sense. What would cause it not to power on and where can I get a part that would fix this possibly? I'd be happy to pay someone or for the part and do it myself because i just spent a good amount for something that broke in my hands for turning a few screws. If you guys could help it would be seriously appreciated even though its my own fault. (Note: there was no static electricity damage done)
4 Related Answers
Starfish Phoenix
  • 73 Answers
SOURCE: alot of the effect on the kaoss pad do not work. but for example effects 90-99 work just fine?
The kaos pad is a mainly input based machine ... You sure you got sound going in?
Posted on May 23, 2009
Michial Gueffroy
  • 1140 Answers
SOURCE: connecting the kaoss pad 3 to my built in turn table mixer
Try connecting the main output to the input of the Kaoss and the output of the Kaoss to your amp. You will get more signal.
Posted on Aug 06, 2009
Anonymous
  • 3 Answers
SOURCE: Korg mini kp only some effects working. Low sound output
I have the same Kaoss Pad mini and have exactly the same problem. I have asked for a solution as well!
The only way I have been able to use live is to turn up master on mixer to compensate, but this is incredibly hard to do if you're not always going through the KP as you have to adjust master volume each time up or down.
I haven't heard any volume problems with the full size Kaoss Pads, think it might just be a KP mini problem.
johnclark
Posted on Aug 22, 2009
Anonymous
SOURCE: Low Volume using Kaoss Pad Mini while DJing
I'm having the problem too...I'm thinking that maybe getting the DC adapter MAY fix it though as stated in the Manual: "...The output level of the mini-KP will be smaller than its input level. This is because the attenuator circuit is connected at the input section, considering that the mini-KP is used on battery power." so maybe the dc connector will increase output volume?
Posted on Jan 30, 2010
I have a Korg KP3 with a faulty touch screen. How can I get this fixed?
Take it appart rub it with pure alcohol an put the touchpad together again
Nov 23, 2014 | Dynamic Korg Kp3 Kaoss Pad Dynamic Dj...
I just got a kaoss pad and having need help connecting to a cdmp 6000 help please
You haven't got a send and return on your cdmp 6000. What I advice you to do is the following: connect the master out, the red/white cinch, to the input of the kaoss pad. Than connect the output of the kaoss pad to your speaker system or reciever. You can now control effects on the master single.
Feb 20, 2010 | Korg Mini Kp Kaoss Pad
Aug 22, 2009 | Korg Mini Kp Kaoss Pad
Connecting the kaoss pad 3 to my built in turn table mixer
Aug 04, 2009 | Korg Mini Kp Kaoss Pad
johnclark
May 28, 2009 | Korg Mini Kp Kaoss Pad
Alot of the effect on the kaoss pad do not work. but for example effects 90-99 work just fine?
May 01, 2009 | Korg Mini Kp Kaoss Pad
What do i need in a mixer? i want to connect my kaoss pad mini, and kaossilator, and obviously a couple of cdjs, and where do i connect them straight in the mixer or amp, im awaiting my purchase and just...
For dj use, industry standard would be something like a Pioneer DJM600 mixer. 4 channels w/ effects and a mic input. To use kaoss it's best to go into Send/Return input through the effects. By tapping on Send, all sound is sent out to the kaoss pad, and comes back into the mixer into the Return inputs. By doing this you can have the kaoss pad on sitting next to the mixer ready to apply effects all the time. Then connect the master outputs from mixer into your amp, or straight to powered speakers. Kaossilator is more of an instrument than effects unit, so plug in to channel 3 after your 2 cdjs in channel 1 and 2. You still have a spare channel left. I use 2 x 1200s and 2 x cdjs with kaoss pad through effects channel in this way. A 4 channel mixer is plenty.
Mar 25, 2009 | Korg Mini Kp Kaoss Pad
Connection problem
simple bro. . .. flick the korg kaoss pads setting to send . . u will find this on the back. . . i thin you have it set to direct. . flick it over to send and then let em know if it works. . . and could u answer ASAP what cords you used to connect the kp3 to the send return on your mixer. . .thanx
Dj Nap
Dec 24, 2008 | Korg Mini Kp Kaoss Pad
Korg Mini Kp Kaoss Pad Logo
Top Korg Music Experts
Vernon Taylor
ADMIN Canada
ADMIN Canada
ray gallant
Are you a Korg Music Expert? Answer questions, earn points and help others
